Amp Wiring Question
Old Feb 11, 2006 | 05:14 AM
PnoyJeff's Avatar
Default Amp Wiring Question
i just wanted to confirm my knowledge since all of you in this forum are more knowledgable than me in this...
when wiring the amp..i know you are supposed to connect the power(positive) wire first. and then connect the ground(negative) after that.
when you connect the power, im thinking the wire shouldnt be live..but i wanted to confirm this
also when connecting the ground..should it already be grounded or should i ground it after connecting to the amp
and then hooking up the rest of the wires comes in no specific order right?
thanks for the help..
Old Feb 11, 2006 | 05:31 AM
B18C_EJ8's Avatar
It really doesn't matter. You're not going to damage anything if you do it any certain way...
Old Feb 11, 2006 | 05:35 AM
PnoyJeff's Avatar
Default Re: (B18C_EJ8)
i have another question..
how can u adjust the impendance, ohms...i should run my sub at 2 ohms, said my friend..but i dont know how to do that..i just know to connect the wires n thats it
n i dont have an ohm meter so how can i check that
Old Feb 11, 2006 | 10:12 AM
fcm's Avatar
fcm
Old Fart
Default Re: Amp Wiring Question (PnoyJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyJeff &raquo;</TD></TR><TR><TD CLASS="quote">i just wanted to confirm my knowledge since all of you in this forum are more knowledgable than me in this...
thanks for the help..</TD></TR></TABLE> As mentioned by B18C_EJ8 it does not matter, what matters is that you have the neg. batt. term. disconnected untill all other connections have been made and checked, the last thing you should be doing is connecting the batt. neg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyJeff &raquo;</TD></TR><TR><TD CLASS="quote">i have another question..
how can u adjust the impedance, ohms...i should run my sub at 2 ohms, said my friend..but i dont know how to do that..i just know to connect the wires n that's it
n i don't have an ohm meter so how can i check that</TD></TR></TABLE> You say sub, as in one, so unless it is a DVC, [dual voice coil] it can't be "adjusted", if it is a DVC sub, then it must be a DVC 4 ohm, so the 2 VCs can be wired together in parallel so you end up with a 2 ohm load.
When you wire VCs , [speakers] together, you can do it in parallel or series, or if more then 2, but always even numbers, VCs a combination of both parallel and series, and how they are wired will determine the the final load, [impedance] or ohms that the amp sees, and must be taken into account when wiring speakers to an amp. 94
Old Feb 11, 2006 | 11:01 AM
PnoyJeff's Avatar
Default Re: Amp Wiring Question (fcm)
thanks....ill be installing it tomorrow though.........it started raining
GetawayInMoscow
Audio / Security / Video
12
Jul 8, 2006 05:57 AM
rollin92
Nov 22, 2005 12:33 PM
sniperslayer
11
Dec 6, 2004 07:34 PM
eL
Jun 17, 2004 08:12 PM
loki2323
Jan 31, 2003 07:55 PM
