why does my car keep bogging out??
Old Feb 8, 2006 | 03:59 PM
hatchinprogress's Avatar
Default why does my car keep bogging out??
ok i just re-bult my dohc zc and today i drove it for the 1st time, but now when i reach 4,000 rpm's my car boggs out... i did a compression test and i got: 160,159,159,152 things that may be the reason:
1) im running a turbo base map on my n/a motor (before the rebuild the car was boosted, but i cant fit my new turbo in the bay so no turbo for now....but im using 450cc injectors so thats why im running the turbo map)
2) my timing it at 21* tdc (this was the lowest i could get w/ dizzy turned all the way back) maybe because the map see's 21* and dumps alot of fuel for the turbo that should be there.
3) my cams, i know have delta re-grinds (272 intake...260 exhaust)
4) my exhaust (cheap ebay header, w/ 2.5 cat back exhaust) back when i had a dx motor it would bogg down due to the big exhaust (maybe it's too much for my non turbo?)
5) my pistons, i have low comp. pistons (since this was/is a planned turbo build) my comp is about 8:1
thanks for anyhelp
Modified by hatchinprogress at 8:08 PM 2/8/2006
Old Feb 8, 2006 | 04:40 PM
Default Re: why does my car keep bogging out?? (hatchinprogress)
any one?
Old Feb 8, 2006 | 05:54 PM
ttt
Old Feb 8, 2006 | 07:08 PM
help
Old Feb 8, 2006 | 07:32 PM
help please!
Old Feb 8, 2006 | 07:35 PM
ghost_ryder35's Avatar
well when my zc bogged down at 4000 it was something to to with the distibuter. I had to get a new rotor. damn thing was in there spinning loosley. Hope that helped a little. Either way if it didnt its a free bump, but I think you should look at your dizzy, its a very common problem over looked
Oh one more thing. 2.5 isnt too much for it. I'm running that on mine and it runs just right
Old Feb 8, 2006 | 08:02 PM
Default Re: why does my car keep bogging out?? (ghost_ryder35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 &raquo;</TD></TR><TR><TD CLASS="quote">well when my zc bogged down at 4000 it was something to to with the distibuter. I had to get a new rotor. damn thing was in there spinning loosley. Hope that helped a little. Either way if it didnt its a free bump, but I think you should look at your dizzy, its a very common problem over looked
Oh one more thing. 2.5 isnt too much for it. I'm running that on mine and it runs just right</TD></TR></TABLE>well the only code im throwint is 10 iat, and as for the exhaust it was just an idea i had to throw out there
Old Feb 9, 2006 | 05:07 AM
fix that code 10 for sure.
Old Feb 9, 2006 | 02:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 &raquo;</TD></TR><TR><TD CLASS="quote">fix that code 10 for sure.</TD></TR></TABLE> what is the code doing to my motor? it's wierd i tested the sensor for resistance and it falls within specs. could it be the low comp causing the car to run the way it does?
Old Feb 10, 2006 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> what is the code doing to my motor? it's wierd i tested the sensor for resistance and it falls within specs. could it be the low comp causing the car to run the way it does?</TD></TR></TABLE> ttt
young geezer
Sep 8, 2011 04:53 AM
eag36
Jan 2, 2006 07:32 PM
crxzcracer
May 18, 2005 01:23 PM
truesleeper
Apr 14, 2005 07:03 AM
