b18c1 in crx i have no fuel pressure
i wanted to know if any one had an idea of what can be wrong with my car i had the wiring double-checked to be sure it was right my fuel pump is getting power and my injectors are too but no gas is flowing into my motor? once again i have a b18c1 motor and my chassis harness was converted to obd1
a fuel pressure gauge will show you if you have fuel pressure. it's a good thing to get to troubleshoot. if your problem is fuel pressure, make sure your fuel pump is getting power first. if your fuel pump is wasted, you need a new one.
if your regulator is bad (i think that's pretty rare), then i would just fork out for a b&m honda one (around $40, adjustable, you can increase/dec fuel pressure as you want)..
do you have a CEL? does the engine run and idle, but just not well? no fuel at all?
no the car doesnt start just turns over fuel pump isnt getting any power nor are the injectors but wiring has been checked by a friend who has done this plenty of times and i do have a aftermarket fuel pressure regulator not sure what brand though
dsmslyr55
Sep 7, 2010 09:20 AM
si90rex
15
May 18, 2010 05:03 PM
