Darn Accord
Darn Accord
After driving and stopping repeatedly throughout the day my car wont start without applying the gas. I Cleaned egr ports and replaced the EGR Valve, cleaned my headers.
Re: Darn Accord
It is probably the fuel pump, or possibly the fuel pressure regulator or the injectors. If it was me I would start by putting some fuel cleaner in it for a tank or two and running it at highways speed a couple of hours. That would clean gunk out of the fuel pump and the fuel injectors if that is the problem. If it persisted, I would borrow/obtain loan of a fuel pressure tester from a place like AutoZone and check the fuel pressure. If the fuel pressure is low at that point, it is probably the fuel pump. If the pressure is good but the problem persists I would pay someone to pressure clean the fuel injectors. Scotty kilmer has youtube videos on "how to clean fuel injectors in your car" and "how to tell if your fuel pump is bad" They can probably tell you what the right fuel pressure is for your car at AutoZone, but if not, you can probably find it on line by googling it. If you want the fastest, most-accurate information on your car you can subscribe to alldatadiy.com for about $30 per year and get all of the factory level maintenance and repair information.
Re: Darn Accord
Low fuel pressure? Check the pressure, me I can go on ebay and buy just the electric motor for $10, Id just swap it out especially of you got over 80k miles on it. Mine failed at around 150k
Cyphear
02-24-2007 01:42 PM
