b16a in a 91 crx si, how to be sure that vtec is working? please help?
Old Mar 25, 2002 | 02:43 PM
kizner's Avatar
Default b16a in a 91 crx si, how to be sure that vtec is working? please help?
How can you be sure that the vtec is absolutely working, I know that this is probably a very stupid question, but im fairly new at this, thanks
Old Mar 25, 2002 | 06:04 PM
Trey's Avatar
25 Year Member
Default Re: b16a in a 91 crx si, how to be sure that vtec is working? please help? (kizner)
If you redline at 8.2k then Vtec is working.
If you redline at 6.2k (roughly) then it isn't
If you have a Vtec ecu, check for codes. There is a clear window on the ecu that has a red LED. See if it's flashing........
Old Mar 25, 2002 | 06:32 PM
Kamin's Avatar
Default Re: b16a in a 91 crx si, how to be sure that vtec is working? please help? (Trey)
umm i may be wrong because this is a first gen engine
but my second gen b16 went happily to 8400 till redline.
like i said.
second gen. not sure on first.
anyone else confirm this?
Old Mar 25, 2002 | 07:09 PM
tommyboy's Avatar
What if the ecu doesn't have a clear window? I have a p28 from a 93 four door ex how do you check for codes on that one.
Old Mar 25, 2002 | 07:18 PM
Kamin's Avatar
Default Re: b16a in a 91 crx si, how to be sure that vtec is working? please help? (tommyboy)
then this dosent apply to you tommyboy. if your engine light is on. post a thread.
Old Mar 25, 2002 | 07:30 PM
tommyboy's Avatar
Default Re: b16a in a 91 crx si, how to be sure that vtec is working? please help? (KAMiN)
my lite is on because of my 02 sensor, I just wanted to know how to check codes if the ecu doesn't have that little window.
Old Mar 25, 2002 | 08:00 PM
crxfactor1991's Avatar
unbolt the exhaust manifold from the exhaust and tie up the exhaust and pull the air box and you will hear vtec if and when it kicks in
or wire up a light to the solenoid
Old Mar 26, 2002 | 06:51 AM
Trey's Avatar
25 Year Member
Well if your car is a 91 Crx and you are using an OBDI ecu then you can't check for codes since the car doesn't have a CEL on the dash. Why not get a PR3 or PW0 ecu and test then......
the_rex
Feb 8, 2008 06:42 AM
jdmef9gsr
Feb 3, 2005 01:06 PM
APEX CRX
Jul 15, 2003 10:29 AM
darrylwfarkas
Feb 20, 2003 09:40 AM
wiber1
Mar 24, 2002 04:21 PM
