89 civic front bumper removal?!
Old Mar 25, 2002 | 12:49 PM
technine's Avatar
Default 89 civic front bumper removal?!
How do I take out the top metal piece above the front bumper? The long metal piece that lines the top just below the headlights. I took out the bolts on the front, behind the corner lights, still won't budge.
I use to have a CRX and I could take the bumper off in minutes. I cannot get to the real bumper screws underneath the metal liner. HELP! TIA
Old Mar 25, 2002 | 01:52 PM
maximedx's Avatar
Default Re: 89 civic front bumper removal?! (technine)
i think to take off the headlight because the metal piece have two scew just beside of the headlight.
Old Mar 25, 2002 | 02:34 PM
technine's Avatar
Default Re: 89 civic front bumper removal?! (maximedx)
how do I take off the head light without taking off the bumper? Man I hate this civic front bumper.
Old Mar 25, 2002 | 02:53 PM
CLICC916's Avatar
my 90 civic si had 2 bolts on each side that bolted onto the fender, and then it had a couple up front....that was it i believe. you are talking about the filler panel right?
Old Mar 25, 2002 | 03:19 PM
technine's Avatar
Default Re: 89 civic front bumper removal?! (CLICC916)
yeah, that is what I'm talking about. But where are those other couple of bolts in the front?
I removed the two bolts behind the corner lamps and the one in the center, but what else? I don't know where the other bolts are? TIA.
Old Mar 25, 2002 | 07:03 PM
flat-blk-HB's Avatar
pull off the head lights..it makes this a whole hell of al ot easier...for the lights there is two bolts up top one on the side and one deep behind the light..use a long exten. to get the bolt behind it out..all 10mm....on e you have this out there is two bolts holding on the filler peiece..i recommend not putting these back in when you are reinstalling the bumper...makes it easier next time....
Old Mar 25, 2002 | 07:25 PM
90civichbsi's Avatar
Default Re: 89 civic front bumper removal?! (89EF-BCUMBIE)
yes i know what you mean, its a pain, when i installed my ww kit i just un did the other bolts and it left me w/ enough room to stick in an between the filler and headlight extension to undo the bolt.
but ur best bet would be to take the light off, when i was installin the kit it was dark outside so i couldnt find the bolts for the headlights
Old Mar 26, 2002 | 11:22 AM
technine's Avatar
Default Re: 89 civic front bumper removal?! (90civichbsi)
thanks guys.
Is that bolt behind the headlight the bolt on the bottom back of it? That is a hard bolt to get to, but I will try... is that bolt necessary when I put the headlight back? I would like to leave that out also. Thanks again all.
RA61825
May 18, 2009 07:20 PM
ryan_crx
Apr 24, 2009 07:42 AM
B16HelpMe
Mar 4, 2007 06:52 PM
949
Oct 5, 2005 04:33 PM
CivicEXGuy
Jul 17, 2004 11:56 AM
