Turbo Fuel Mangement System Recommendation!
What do you guys recommend for a Fuel Setup System for a Turbo? I mean what parts do I need to support enough Fuel for the Boost that i'm running, from Fuel Injectors (what CC) to what harness will fit that injectors?, FMU or Apexi or Hondata. Like a complete fuel system that will make the car perform right at a centain amount of boost. Let's say i'm running 7PSI.
AFC hack = bad timing = kaboom.
https://honda-tech.com/zerothread?id=841443
for obd2 theres emange and afc hack, both suck IMO.
get an obd1 conversion harness an p28 or p06 ecu depending on what engine you have and go hondata. i would say uberdata or crome but it sounds like at this stage this would be a bit confusing/complex to you unless you sit down and do a good amount of researching.
