Car wont start in the Morning when its cold. NEED HELP!!!!
Old Feb 3, 2006 | 07:47 AM
BPAccord's Avatar
Default Car wont start in the Morning when its cold. NEED HELP!!!!
I just had my 2000 Honda Accord Ex Manual 2dr coupe for about two months now. Recently it hasnt been starting in the morning when its cold. It seems like as if there isnt any power at all going to the car when its cold. Ive tried taking off the battery terminals and even replacing as i thought they were corroded. The problem still persists, but i notice that when the weather gets warm around 11 o'clock in the afternoon then the power comes back on. I dont even have a clue of where to start. If its the battery then the car shouldnt start at all. I replaced the terminals and it still doesnt start in the morning when im trying to go to work but the power comes back on in the afternoon. If any of you have any suggestions it would really help to see where i should start . Thank You.
Old Feb 3, 2006 | 09:32 AM
NYCsnowman's Avatar
Default Re: Car wont start in the Morning when its cold. NEED HELP!!!! (2000MugenAccord)
cold in cali... ? check battery voltage in the morning. low temps reduce cranking amperage and voltage.
if the temp difference in pamona... lol... is 20 to 30 degrees during the day u might need a new battery.
Old Feb 3, 2006 | 10:47 AM
Honda_Accord's Avatar
Default Re: Car wont start in the Morning when its cold. NEED HELP!!!! (NYCsnowman)
ya i didnt know it got cold in cali, last time i checked it was in the high 70's.. how early in the mourning u talkin?
but anyways, ya each battery has a cold and heat cranking amps.. if your cold cranking isnt high enough your car will not obviously start as your stating..
Old Feb 3, 2006 | 02:14 PM
cdx280's Avatar
Default Re: Car wont start in the Morning when its cold. NEED HELP!!!! (Honda_Accord)
if the battery isn't new, replace it. make sure the terminals are clean or try replacing the cable if it is corroded.
Old Feb 3, 2006 | 02:46 PM
BPAccord's Avatar
Thanks a lot for all the replies. will go and replace battery now... and its not that cold in cali... probably lowest is like 60 in the morning but cold enough for my damn car not to start. thanks alot fellas appreciate it
Old Feb 8, 2006 | 07:53 AM
BPAccord's Avatar
Alright guys i tried replacing new battery terminals... still wont start when its cold..... even got a new battery put it...still wont start when its cold... for some stupid reason the car still wont start until it gets warm around 11:00 o'clock.... I dont know what else to do... im having a mechanic do a diagnostic test on it ... but if any of you guys have any more suggestions please they are most needed.. Thank You ahead of time....
Old Feb 14, 2006 | 11:32 AM
BPAccord's Avatar
Hey guys i had everything replaced and had the mechanic run a test on it and nothing came up.... but he told me he noticed that when he touches the fuse box the car come back on even when it was cold...... any suggestions on why this would happen?
Old Feb 14, 2006 | 02:08 PM
P_Adams's Avatar
Default Re: (2000MugenAccord)
Have him check the large 50 amp master fuse marked "Ignition Switch", the equally large 80 amp "Battery" master fuse and their Fuse Box contacts. It shouldn't be doing that.
P
Old Feb 15, 2006 | 02:45 PM
BPAccord's Avatar
Will Do.... Thanks alot for the reply... will keep everyone posted and hopes this never happens to anybody who has to work mornings......
dvanommen
20
Aug 16, 2019 12:45 PM
dohc_profile
Oct 12, 2007 11:32 PM
vlc92189
Jan 30, 2007 04:53 AM
sinfulj32
Sep 25, 2006 12:08 PM
Sticky Tires
Feb 12, 2003 01:18 AM
