Car wont start.
Old Feb 2, 2006 | 08:41 PM
TURBOWHT's Avatar
Default Car wont start.
I have a 92 civic i just recently did a b18a turbo swap. Im running a walbro fuel pump and precision 780 cc injectors. I am running hondata s300. So the problem. It acts like it wants to turn over. But never does. The car is getting fuel and spark. I took the plugs out and They are drenched with Gas. I have the obd0 throttle body on there, and it only has a tps sensor. You think thats why im getting alot of fuel and flooding it. Im going to be getting a obd1 so it will have both tps and map sensors on it. Do you guys think this is what my problem is. Or is there other things i can check for? thanks
Old Feb 2, 2006 | 08:43 PM
96-EJ6 B18C's Avatar
Default Re: Car wont start. (TURBOWHT)
Did you scale your fuel map for the 780's, I'm guessing not if the plugs are soaked.
Old Feb 2, 2006 | 08:48 PM
TURBOWHT's Avatar
Default Re: Car wont start. (96-EJ6 B18C)
Im not sure, i had a friend do a base map for me. Im a noob with the hondata. I would of thought he would of. I have also tryed searching to get a good base map before i posted but couldnt really find any good information. Anyone good with making base maps.
So not having the map sensor hooked up has nothing to do with it running way to much fuel?
Old Feb 2, 2006 | 08:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBOWHT &raquo;</TD></TR><TR><TD CLASS="quote">So not having the map sensor hooked up has nothing to do with it running way to much fuel? </TD></TR></TABLE>
for me! Sorry I missed that! That will absolutely have something to do with it not starting, get a MAP hooked up ASAP. If it still won't start and the plugs are still wet with fuel, then I would suspect the fuel map was not scaled properly for the injector size.
Old Feb 2, 2006 | 09:01 PM
TURBOWHT's Avatar
Its alright thanks for the help. Hopefully thats why it isnt starting.
Old Feb 2, 2006 | 09:05 PM
Yeah best of luck, if your still having problems with it just shoot me a PM, I'll see if I can maybe whip you up a map that will be closer.
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
ashb82
11
Aug 3, 2012 01:22 PM
A13sechatch
Jul 26, 2009 02:48 PM
Akalima
Jun 2, 2008 04:03 PM
D-Rizzle3
Mar 1, 2008 09:51 AM
