what is optimum oil psi for a turbo to get
Old Feb 2, 2006 | 04:56 PM
97grnrs's Avatar
Default what is optimum oil psi for a turbo to get
i know everyone says it junk but i got an xs power turbo kit. i am going to be using a needle valve as a restrictor to the turbo . what is the oil pressure supposed to be set at at idle( between restrictor and turbo inlet) ? how much should it be at full throttle? if i set the oil pressure to the turbo at idle to whatever its supposed to be then its done right? d series motor
Old Feb 3, 2006 | 06:01 AM
97grnrs's Avatar
Default Re: what is optimum oil psi for a turbo to get (97grnrs)
anyone. in general? idle psi?
Old Feb 3, 2006 | 06:50 AM
dannydos's Avatar
it depends on the turbo.....i have a turbonetics turbo and i see about 50psi from 4grand to redline....make sure your oil return line is setup correctly.....but most turbos don't like to see the 75psi that comes off the back of the block it's usually about 30-50psi that's good for turbos....any higher and you'll have blow by....
Old Feb 3, 2006 | 02:38 PM
97grnrs's Avatar
Default Re: what is optimum oil psi for a turbo to get (dannydos)
so what is it at idle then?
Old Feb 5, 2006 | 12:18 PM
97grnrs's Avatar
someone has to know
Old Feb 5, 2006 | 12:21 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannydos &raquo;</TD></TR><TR><TD CLASS="quote">it depends on the turbo.....i have a turbonetics turbo and i see about 50psi from 4grand to redline....make sure your oil return line is setup correctly.....but most turbos don't like to see the 75psi that comes off the back of the block it's usually about 30-50psi that's good for turbos....any higher and you'll have blow by....</TD></TR></TABLE>
Sooooooo 85 might be a tad high? haha
Old Feb 5, 2006 | 12:26 PM
y7turbo's Avatar
Default Re: what is optimum oil psi for a turbo to get (Dunc)
i have a .055" restrictor on mine.. it "sees" 5 psi at idle and 28 at redline. some turbos can take alot more but why find out the hard way..
Old Feb 5, 2006 | 03:15 PM
97grnrs's Avatar
Default Re: what is optimum oil psi for a turbo to get (y7turbo)
this is a t3/t4 turbo.. not too big .. so if i set to about 7-8 psi at idle u think it will be ok?
Old Feb 5, 2006 | 05:23 PM
diet rite's Avatar
restrictors clog.
Old Feb 5, 2006 | 05:26 PM
Dunc's Avatar
BCICAN
Default Re: what is optimum oil psi for a turbo to get (diet rite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diet rite &raquo;</TD></TR><TR><TD CLASS="quote">restrictors clog.</TD></TR></TABLE>
Clean them with every oil change then
Old Feb 6, 2006 | 06:50 AM
97grnrs's Avatar
mine is just a needle valve. anyone.
91-lsvtecsi
Aug 8, 2017 03:19 PM
Firstoost
Oct 15, 2005 05:23 PM
Siguy00
Apr 28, 2005 07:42 AM
nortel
Feb 11, 2003 12:33 PM
GSRacer
Oct 30, 2001 12:28 PM
