my motor shuts off while driving
Old Feb 2, 2006 | 12:58 PM
ekjay's Avatar
Default my motor shuts off while driving
I have an ls swap in my 98 hatch and it recently its been shuting off while im driving. It will restart after a few tries and run fine and then randomly shut off again anyware from minutes to days later. Has anyone had this problem or have any idea what would cause it?
Old Feb 2, 2006 | 01:22 PM
93civciv's Avatar
Default Re: my motor shuts off while driving (ekjay)
wow i would check out your grounds or something cuz thats gotta suck driving and not know if your car is going to die....it might just be a loose ground....
Old Feb 2, 2006 | 05:17 PM
ekjay's Avatar
Default Re: my motor shuts off while driving (93civciv)
All my ground wires are fine. Could it be something elecrical or possibly fuel related?
Old Feb 2, 2006 | 07:37 PM
93civciv's Avatar
well i had a prob one time with the ecu fuse in the engine bay being loose..causing everything to shut off....maybe check that...its the 20amp fuse in the top left...next to the back up...
Old Feb 2, 2006 | 07:58 PM
pinoyguy1986's Avatar
check your ignition switch... the wires inside may be loose you may have to resolder them... im having the sme prob in my 98 sedan... sometimes my starter stays on even when i pull the key out lol.... my mechanic told me this happens to hondas but yeah check your ignition switch
Old Feb 2, 2006 | 09:06 PM
K i l l a B e e.'s Avatar
Default Re: my motor shuts off while driving (pinoyguy1986)
you're stalling just messing.
Old Feb 2, 2006 | 09:50 PM
Do_Ster's Avatar
when you say shut off does it just dies at a stop light or does it sputter a bit first? it may be possible its fuel related,(filter, pump,etc.)
Old Feb 2, 2006 | 11:09 PM
RTI's Avatar
RTI
Default Re: (Do_Ster)
change the main relay.
Old Feb 3, 2006 | 02:41 AM
mattbishop's Avatar
check the IACV
bnmm
Sep 26, 2011 07:24 AM
jolecai23
Jan 8, 2010 09:19 AM
philosofy1
12
Jul 28, 2006 11:57 AM
r3v da t3g
May 15, 2005 12:20 PM
TheStryder
Nov 26, 2003 03:20 AM
