fixed O2 sensor and still pulling O2 sensor code.
Old Feb 1, 2006 | 01:47 PM
stattonmw's Avatar
Default fixed O2 sensor and still pulling O2 sensor code.
Ok so i put a 4-1 DC sports header on my 98' civic ex. with the installation of the header the placement of the O2 sensor was moved to just behind the oil pan. the headers came with an exstension wire and after the installation the check engine light would periodically come on so i replaced it with a brand new one and now the light wont go off and im still pulling the same code.
a note when i first replaced it the wires on the O2 sensor were switched i thought that was the problem but i guess not... Any suggestions on what it could be?
thanks
Old Feb 1, 2006 | 03:00 PM
pip9's Avatar
Default Re: fixed O2 sensor and still pulling O2 sensor code. (stattonmw)
whats the code?
Old Feb 1, 2006 | 03:28 PM
ABK's Avatar
ABK
Default Re: fixed O2 sensor and still pulling O2 sensor code. (pip9)
you prolly wired something wrong, or the wire that came with the kit is a wrong size, or wrong metal. DC junk
Old Feb 1, 2006 | 04:12 PM
Ross 2.0's Avatar
In a Junkyard near you.
is the sensor before or after the converter now?
Old Feb 1, 2006 | 04:17 PM
all_conference's Avatar
"the installation the check engine light would periodically come on so i replaced it with a brand new one and now the light wont go off and im still pulling the same code"
same thing happened to me...except..the code was 48 with old sensor and now its 41 + 48 with constant CEL...weird...
Old Feb 1, 2006 | 05:00 PM
nekoabandoned's Avatar
Default Re: (all_conference)
check the wires that lead from the o2 to the ecu,soemtimes when it shows a code for a bad ecu its a burnt wire.
Old Feb 1, 2006 | 11:50 PM
stattonmw's Avatar
its right before the converter. and i know the wires fit right with the exstension. what do you mean the wrong kind of wires?
Zac W.
May 15, 2012 08:22 AM
924drb20
Dec 14, 2010 10:36 AM
messeduprex
Apr 11, 2005 08:08 AM
2camsaam
Feb 17, 2003 05:58 PM
baonest
Jun 24, 2002 06:48 PM
