JDM M2B4 Tranny (VSS)
Old Feb 1, 2006 | 05:50 AM
Yuleluder's Avatar
Default JDM M2B4 Tranny (VSS)
Does anyone know what the deal is with the power steering line which runs under the VSS on the Tranny? I am doing a auto to manual swap and I see these two line running under the VSS. I take a look in the front clip and I see that the line runs into the powersteering resevoir. Do I need this for my swap?
Old Feb 1, 2006 | 09:09 AM
SteveoBA8's Avatar
Default Re: JDM M2B4 Tranny (Yuleluder)
Those power steering lines going to the Vss are for the Variable Assist Power Steering.
Old Feb 1, 2006 | 01:01 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yuleluder &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know what the deal is with the power steering line which runs under the VSS on the Tranny? I am doing a auto to manual swap and I see these two line running under the VSS. I take a look in the front clip and I see that the line runs into the powersteering resevoir. Do I need this for my swap?</TD></TR></TABLE>
No you don't need to hook those pipes up to anything. I just left both of mine open.
Old Feb 1, 2006 | 01:02 PM
K-Spec's Avatar
Default Re: JDM M2B4 Tranny (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Those power steering lines going to the Vss are for the Variable Assist Power Steering. </TD></TR></TABLE>
Do you know exactly how that works?
Old Feb 1, 2006 | 05:27 PM
SteveoBA8's Avatar
Default Re: JDM M2B4 Tranny (khalal538)
The power assist is proportional to the vehicle speed and steering load. So when the vehicle is in motion( i dont know the exact mph cutoff) the speed sensor pump( the sensor itself is a trochoid-rotor hydraulic pump) relieves a portion of the hydraulic pressure thus reducing power steering assist.
Old Feb 1, 2006 | 06:01 PM
K-Spec's Avatar
so for example, when you are at high speeds, the steering tightens up as opposed to at low speeds, the steering is loose?
Old Feb 1, 2006 | 06:03 PM
mgags7's Avatar
^^exactly....it makes the rack harder to turn at higher speeds....
Old Feb 1, 2006 | 06:46 PM
roller3804's Avatar
Default Re: (mgags7)
I love that about my prelude
Old Feb 3, 2006 | 04:34 PM
K-Spec's Avatar
so...ok, i have a M2B4 tranny in my 5th gen which already has a power steering pump. How and where would I hook up those lines from the tranny to? Any ideas?
Old Feb 3, 2006 | 05:45 PM
v4lu3s's Avatar
RTFM
as far as i know only 4th gen accords and 4th gn ludes have thevariable power steering assist.
Old Feb 8, 2006 | 11:16 AM
K-Spec's Avatar
Default Re: (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">so...ok, i have a M2B4 tranny in my 5th gen which already has a power steering pump. How and where would I hook up those lines from the tranny to? Any ideas?</TD></TR></TABLE>
1993gsrcivic
Feb 8, 2009 07:20 AM
MidShipCivic
Welding / Fabrication
27
Jul 9, 2007 12:36 PM
lilbinky
Mar 30, 2007 08:36 AM
SpOoNisMyFriEnD
10
Apr 1, 2005 06:53 AM
Hockey27925
Mar 25, 2005 10:38 AM
