Help, Bad distributor or igniter? Car stopped running!!
Old Jan 31, 2006 | 07:25 PM
petros600's Avatar
Default Help, Bad igniter?Update Timing belt broke!!!!
I need some help, while was driving and came to a light the car just died on me. It cranks but doesnt start. While my brother was trying to start i took off one of the spark plug wire and i wasnt geting any spark.
Is the distributor the problem and do i need to buy a new one? Any suggestions how to fix it?
The car (91 HF)has a B16a swap, OBD0 with Zyden ecu
Any help or direction on how to fix it it will be great.
Thanks
Modified by petros600 at 10:40 AM 2/5/2006
Modified by petros600 at 11:29 AM 2/5/2006
Old Jan 31, 2006 | 07:55 PM
naptownrex's Avatar
Default Re: Help, Bad distributor or igniter? Car stopped running!! (petros600)
Ive got my money on the coil... If you did the swap your self, take the coil out of your old dizzy, and throw it in the b16 dizzy. Also, Im assuming your getting fuel??? (if you try to start the car, and then pull the spark plug out and its covered in fuel, then its probably your ignition system). Its doubtful that your timing belt would go, but it wouldnt hurt to check. but yeah, ive got money on the coil... but check your rotor too... may as well just do a whole tune-up...
Old Jan 31, 2006 | 08:02 PM
jdmcars.com's Avatar
My guess would be igniter, then maybe coil.
Could also be something else too.
You could pull off the cap -inspect the rotor button and cap -while off -also bump over engine to make sure you see it spin the rotor button.
If so, try to swap igniter's if you have one around.
Old Jan 31, 2006 | 09:33 PM
petros600's Avatar
Can i use the igniter and the coil from my D16 dizzy?
Also you mention the timing belt, i am not that familiar, why i should have problem with the timing belt?
Thanks again
Old Jan 31, 2006 | 09:34 PM
SiR Inspired ED7's Avatar
when you crank it does it backfire?
Old Jan 31, 2006 | 09:38 PM
petros600's Avatar
Default Re: Help, Bad distributor or igniter? Car stopped running!! (88 Crx Si)
backfire? what do you mean?
Old Jan 31, 2006 | 10:33 PM
when you try to crank it does it pop (backfire) (exhaust)
i member when something like this happend, it would pop(backfire) when i tried to turn it on, the car was driving normal than hesiated than bogged down and died, problem was that the lil screw that holds the rotor (in the distributer cap) was loose (off) cause it not to have spark, check that if, u have not so, it might be your problem
Old Feb 2, 2006 | 05:17 AM
naptownrex's Avatar
yeah, all the pieces of the d16 dizzy are compatable with the b16a, but the whole dizzy wont fit properly
Old Feb 2, 2006 | 06:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petros600 &raquo;</TD></TR><TR><TD CLASS="quote">Can i use the igniter and the coil from my D16 dizzy?
Thanks again
The coil and igniter from the D16 can be used, but the igniter for a B16A calls for a different part number. Though the D16 can be used, normally it will blow out again quicker than having the proper on later installed.
THe timing belt -if it where to snap, the cams would not spin -there for nothing in the dizzy would spin -giving you no spark. This is why I said you can remove the cap, and then try to bump it over to see if it spins. If it spins -the belt is not broke (no worries about that part then).
Old Feb 5, 2006 | 09:39 AM
petros600's Avatar
Default Re: Help, Bad distributor or igniter? Car stopped running!! (jdmcars.com)
Finaly i work on the car today. The timinig belt broke!!!!!
The motor is B16, can i just replace the belt? What else should i replace? I didnt hear any metal noise when the motor stopped
Thanks
Old Feb 5, 2006 | 09:44 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petros600 &raquo;</TD></TR><TR><TD CLASS="quote">Finaly i work on the car today. The timinig belt broke!!!!!
Thanks</TD></TR></TABLE>
very good chance that it bent some valves
Old Feb 5, 2006 | 10:09 AM
petros600's Avatar
Default Re: Help, Bad distributor or igniter? Car stopped running!! (jlicrx)
even i didnt hear any noises? How can i check?
Old Feb 5, 2006 | 10:20 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petros600 &raquo;</TD></TR><TR><TD CLASS="quote">even i didnt hear any noises? How can i check?
you could put a belt on it and do a compression test or you could pull the head
Old Feb 5, 2006 | 10:31 AM
petros600's Avatar
what else should i change while i am doing the belt? I dont know the history of the car, i bought it with b16.
Old Feb 5, 2006 | 10:37 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petros600 &raquo;</TD></TR><TR><TD CLASS="quote">what else should i change while i am doing the belt? I dont know the history of the car, i bought it with b16.</TD></TR></TABLE>
water pump and tensioner for the belt
Old Feb 5, 2006 | 10:44 AM
petros600's Avatar
thanks, also OEM of after market?
Old Feb 5, 2006 | 10:47 AM
jlicrx's Avatar
i would only use OEM
Car Tweaker
May 15, 2009 10:21 AM
chewiejdh
Feb 29, 2004 09:47 AM
GQ Cowboy
Dec 14, 2003 09:55 PM
wu tang
11
Sep 18, 2002 09:15 PM
gsrvx
Jun 6, 2002 11:27 AM
