need help !@!!!!!!!!!!!!!!!!!1
k i wsa driving doing 30mph and then all of a sudden the car died. it caranks and the lights work but it wont start. it's on a stock 93 integra ls.
how do i check the compression if the belt snapped. do i set both the gears at tdc. or ? how do i do it. or would it be safer just pulling the head off and checking that way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPT.PANDA »</TD></TR><TR><TD CLASS="quote">how do i check the compression if the belt snapped. do i set both the gears at tdc. or ? how do i do it. or would it be safer just pulling the head off and checking that way</TD></TR></TABLE>
If you want to proceed with the compression test, you have to properly install the timing belt back before. I would suggest you do that, then if you have compression problem b/c of a bent valve, you can then pull the head. Many times, a snap timing belt does not mean a bent valve...so keep you hopes up. Good luck
