setting ignition timing
Old Jan 30, 2006 | 08:17 PM
CivicVX94's Avatar
Default setting ignition timing
i'm going to be setting the ignition timing on my friends crx tomorrow. it has a b18b in it and i'm not sure if it's obd1 or 0.
Can anyone tell me exactly how to set/check the timing? Do i need to jump the ecu? if so where is the plug at to do so? i have the light and have done it before on my ls, but it's obd1 and i've never really worked on a crx or any obd0 car
thanks for any help
Old Jan 30, 2006 | 08:26 PM
VtecSyndrome's Avatar
Default Re: setting ignition timing (CivicVX94)
You adjust it the same on all B-series, get your light, check the timing and adjust the dizzy if needed. You don't need to mess with the ECU at all.
Old Jan 30, 2006 | 08:28 PM
bag's Avatar
bag
Default Re: setting ignition timing (VtecSyndrome)
dunt 4get abowt the service jumper..If dunt doo that the ecu wil set timin bak 2 stok..on mi car it under dash on pasengir side of interier..
Old Jan 30, 2006 | 08:39 PM
CivicVX94's Avatar
Default Re: setting ignition timing (BRIJPURT13B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">You adjust it the same on all B-series, get your light, check the timing and adjust the dizzy if needed. You don't need to mess with the ECU at all.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRIJPURT13B &raquo;</TD></TR><TR><TD CLASS="quote">dunt 4get abowt the service jumper..If dunt doo that the ecu wil set timin bak 2 stok..on mi car it under dash on pasengir side of interier..</TD></TR></TABLE>
great thanks for the input/help
Old Jan 30, 2006 | 08:42 PM
So you still can't manage to reach the spell checker I see!
javascript:SpellCheck('spellcheck.honda-tech.com',%20'2');&lt;&lt;HERE IS THE DAMN SPELL CHECK LINK HAVE IT TATTOOED TO YOUR FOREHEAD AND USE IT!!!!!OR STOP POSTING PLEASE!!!
flanker
10
May 23, 2008 09:02 PM
jaydmtim
Sep 11, 2007 06:33 AM
casmall08@yahoo.com
Jun 12, 2007 06:14 PM
99lspwr
Nov 29, 2005 03:23 PM
hatchinprogress
Jan 7, 2005 10:06 AM
