ECU question
Old Jan 30, 2006 | 02:18 PM
QUICKERSILV3R's Avatar
Default ECU question
I have a 99 Civic Lx with a 99-2000 Civic Si wiring harness I just purchased a 92-95 JDM b16a from HMotorsonline.com and was curious if I can use a 94-95 GSR ecu for my car I already have the obdII to OBDI conversion harness. The B16 is going to be used with my GSR transmission..
any help would be great
Carlton
Modified by QUICKERSILV3R at 1:13 AM 1/31/2006
Old Jan 31, 2006 | 01:20 AM
civicman02's Avatar
I think that if you used the gsr ecu it would throw a cel because your b16 doesn't have intake butterfly's and I think gsr's have egr valves but i might be wrong about that. anothing thing is make sure your jumper harness is obdIIb to obdI.
Old Jan 31, 2006 | 03:45 AM
eg2sol's Avatar
Default Re: ECU question (QUICKERSILV3R)
You can run it I had to run one before but i throws a cel and it sputters really bad for 4500 to about 6000 rpm.
Old Jan 31, 2006 | 10:47 AM
Default Re: ECU question (eg2sol)
allright thanks guys so I can do it until i get the JDM p30 thanks for the input
Old Feb 1, 2006 | 12:29 AM
Katman's Avatar
you can use a P72 ecu on a B16A engine. You will NOT get a check engine light for the IAB's, but the downside is that VTEC will kick on at 4400-4500rpm which is a bit early....hence the boggyness. You could have the P72 reprogrammed with a P30 map though..
Mass13
Honda CR-V & Element
12
Mar 24, 2014 04:39 AM
cleanM1
Sep 7, 2013 11:54 AM
---SPEED-DEMON---
Feb 11, 2008 03:56 AM
LiL_Shaun
Oct 12, 2007 11:00 PM
Phatch99
Jun 30, 2004 11:25 AM
