ek suspension on eg
Old Jan 28, 2006 | 11:12 PM
myronwong's Avatar
Default ek suspension on eg
hey had a question was wondering will ek shocks fit on an eg? will the springs fit too? springs for civics is 88-00 correct?
Old Jan 29, 2006 | 01:00 AM
t0ekn3e's Avatar
ek shocks will fit in the front but in the rear you have to shave the bushings i think down
Old Jan 29, 2006 | 02:05 AM
BlueIntegraBoy's Avatar
Default Re: ek suspension on eg (myronwong)
Fronts fit. Springs fit. Rears will fit with grinding of the LCA.
Old Jan 30, 2006 | 09:22 PM
myronwong's Avatar
Default Re: ek suspension on eg (BlueIntegraBoy)
what part do i grind down any pictures?
Old Jan 30, 2006 | 10:11 PM
RTI's Avatar
RTI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myronwong &raquo;</TD></TR><TR><TD CLASS="quote">what part do i grind down any pictures?</TD></TR></TABLE>
you grind the bushing that the lower end of the shock bolts to. It is probably faster if you just cut it.
Old Jan 31, 2006 | 06:34 PM
myronwong's Avatar
Default Re: ek suspension on eg (RTI)
so i can't force it in or anything? so i should just cut just the bushing? i don't have to do anything to the control arm?
Old Jan 31, 2006 | 09:33 PM
RTI's Avatar
RTI
you will have to do grind or cut the bushing with it in the control arm unless you have a press. You will not be able to bend the lower shock mounting point enough to make it fit properly.
Old Feb 1, 2006 | 02:37 PM
myronwong's Avatar
can i take the ek lower control arm an put it on?
Old Feb 1, 2006 | 02:41 PM
pdiggitydogg's Avatar
no, the lca's are different sizes
You could use an ek bushing, I think...but thats more work than Id want to do
Old Feb 1, 2006 | 08:44 PM
myronwong's Avatar
Default Re: (pdiggitydogg)
would it if i have spare lca from another eg. can't i just buy the bushing and go get it pressed in?
Old Feb 2, 2006 | 10:14 AM
RTI's Avatar
RTI
Default Re: (myronwong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myronwong &raquo;</TD></TR><TR><TD CLASS="quote">would it if i have spare lca from another eg. can't i just buy the bushing and go get it pressed in?</TD></TR></TABLE>
Getting it pressed in is more work than cutting/grinding the existing bushing. I don't know for sure if you can press in an ek bushing into an eg arm.
Old Feb 2, 2006 | 09:43 PM
myronwong's Avatar
Default Re: (RTI)
i c i will try and figure it out
Old Feb 5, 2006 | 03:47 PM
sIr.fR's Avatar
Ariddle25
11
May 3, 2011 05:58 AM
jaybird8805
Apr 1, 2009 03:47 PM
Orientalbigboi
Sep 8, 2007 11:22 AM
NH578
May 26, 2006 03:49 AM
vizsual00
24
May 26, 2004 10:09 PM
