Bolt-in cage comparison
I am working on making a simple rollbar setup for my CRX right now. We've got everything bent and ready to put in, however....the support bars (which I am mounting behind the rear speaker grills similiar to the autopower bar) cannont come back out of the mounting position without gettig cought. We are having a tough time getting the bars correct so that the kit can come out without having to remove interior etc. My question is, would I be risking much if I simply used a bolt-on design to connect the support bars to the main hoop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA6 »</TD></TR><TR><TD CLASS="quote">Autopower bars use a bolt on setup to connect the rear support tubes to the main hoop - so i'd say you'd be ok.</TD></TR></TABLE>
Awesome, I thought they were welded!
96 GSR-T
Welding / Fabrication
14
Mar 24, 2008 09:20 AM
