CEL on getting P0420
Old Jan 28, 2006 | 02:16 AM
pumpkyn's Avatar
Default CEL on getting P0420
Catalyst System Efficiency Below Threshold (Bank 1)
Now that is the O2 sensor after the Cat, right?
Old Jan 28, 2006 | 04:06 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: CEL on getting P0420 (pumpkyn)
yes. highflow? gutted? sim?
Old Jan 30, 2006 | 04:05 PM
pumpkyn's Avatar
Default Re: CEL on getting P0420 (boostedcivicsir)
stock cat, plus while driving the light went off by itself.
Old Jan 30, 2006 | 04:48 PM
Ross 2.0's Avatar
In a Junkyard near you.
You might have an o2 sensor goofing up. The catalytic converter could be the culprit. Get your hands on an infrared thermometer and take two temprature readings at the converter one in front and one in the back. There should be 100 degrees difference between the inlet and outlet witht the car running and hot. If there is 100 degrees or more the converter is good and you have an o2 sensor going bad.
Old Jan 30, 2006 | 05:06 PM
hondamonkey's Avatar
is that the first o2 sensor or the second....because i have the same code...but im not sure which sensor i might need. The second sensor is way more expensive than the first one. Anyone know for sure??
Old Jan 30, 2006 | 11:59 PM
pumpkyn's Avatar
Default Re: CEL on getting P0420 (hondamonkey)
Im getting the Denso universal which is $60 for both. im going to replace the one after the cat first. Should I replace both sensors at teh same time? or is one just fine.
And thanks for the throstat idea im going to try that out
sfgiants11
Jun 5, 2005 07:22 AM
13link EG
Oct 13, 2004 09:18 PM
Nero2007
11
Jul 28, 2004 04:22 PM
Canuk_SiR
Jul 18, 2002 02:42 PM
degradated
Nov 5, 2001 02:57 AM
