92 honda accord What is the easiest way to take out the brake rotor????
Old Jan 27, 2006 | 06:40 AM
Racersky's Avatar
Default 92 honda accord What is the easiest way to take out the brake rotor????
Old Jan 27, 2006 | 06:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 92 honda accord What is the easiest way to take out the brake rotor???? (Racersky)
not trying to be a dick, but please search. This has been covered before, more than once. I think there is even a write-up done on it.
Edit:
ok, found that write-up for you.
https://honda-tech.com/zerothread?id=1281812
(even though it says it's for a 1997, the 90-97 Accord front brakes are pretty much the same so it'll be very similar)
And heres a few other threads that may help as well.
https://honda-tech.com/zerothread?id=1432145
https://honda-tech.com/zerothread?id=1060259
https://honda-tech.com/zerothread?id=1461095
Just try searching under the recent and Achived threads using "front brake", "front brakes", "Front rotor", ect. You'll find many threads to read through. You'll find what worked for some people and what didn't for others. Take everything into account so when you go to do the job your well prepared.
Modified by TouringAccord at 11:03 AM 1/27/2006
Old Jan 27, 2006 | 07:50 AM
amckee's Avatar
Easy and brake rotor should never appear in the same sentence when refering to a Honda.
Old Jan 27, 2006 | 07:53 AM
H-T Order of Merit
Default Re: 92 honda accord What is the easiest way to take out the brake rotor???? (amckee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee &raquo;</TD></TR><TR><TD CLASS="quote">Easy and brake rotor should never appear in the same sentence when refering to the front brakes of a 90-97 Honda Accord.</TD></TR></TABLE>
fixed
Old Jan 27, 2006 | 07:57 AM
amckee's Avatar
Default Re: 92 honda accord What is the easiest way to take out the brake rotor???? (TouringAccord)
carid
Feb 8, 2016 03:09 AM
Honda cd65
Sep 25, 2013 11:28 PM
randrade24
Jun 14, 2007 06:42 PM
Greyout
Feb 5, 2005 03:02 PM
MilkeySD
Aug 15, 2004 07:47 AM
