dilemma
Old Jan 26, 2006 | 05:49 PM
mluckxxx's Avatar
Default dilemma
alright so im throwing a cel 67, somethings wrong with my cat. i have a d16y7, stock exhaust manifold with the cat right under the heat shield, and something rattling. for 175 bucks i could have meinekee run 2.5" pipe from my exhaust manifold to my magnaflow muffler, would they be able to replace that cat? im not used to seeing a cat right up by the manifold, is this even worth it considering im going to swap a b series into it in a matter of months (maybe years with how my cash flow is comin in.) basically i want to know if changing my cat will even fix my cel, and maybe the rattling sound coming from the bay?
Old Jan 26, 2006 | 06:04 PM
s_vares's Avatar
Please be carful my friend, it may NOT be your cat but it may be your 2nd O2 sensor. This one tells the car how the exhaust is after the cat and if its in tiptop shape. The ratting sound is usually just the heat sheild. The spot welds break causing that. 2 ways to fix, 1 weld
2 (my fav in the shop) use a LARGE hose style gear clamp (like used on rad hoses) and tighten it around the sheild.
Please check your O2 as cats usually have a long life. if your unsure get a shop to check it for you.
Steve
Old Jan 26, 2006 | 07:20 PM
mluckxxx's Avatar
Default Re: (s_vares)
thank you, anyone else?
Old Jan 27, 2006 | 09:46 AM
mluckxxx's Avatar
Default Re: dilemma (mluckxxx)
also, i was wondering HOW MUCH of a help is this heat shield on the exhaust manifold? chould i just cut it off?
CO671
Sep 1, 2012 08:04 PM
euphanom
Aug 12, 2010 05:36 PM
925EKCOUPE
10
Jun 22, 2009 05:18 PM
JDMEK9R
Jan 9, 2008 10:58 AM
SpoonLx
Jan 19, 2005 10:49 PM
