b16 going in 91 hatch
alright the connector on the back of the block is knock right? so i wouldn't have anything running to this? cuz i have all my plugs in IACV and little white sensor on intake manifold and this is the only one without a plug, can i just run it like this or what? ecu= p28 chipped
The Knock sensor is located on the back of the block, under the intake manifold, it is a green colored end sensor.
If you are running P28- correct -you can run without it.
importkidd
10
Jul 27, 2007 10:44 AM
