speed sensor? are b and d series tranny the same?
Old Jan 25, 2006 | 04:28 PM
jccrxtuner916's Avatar
Default speed sensor? are b and d series tranny the same?
after the b16 swap it worked fine and soon enough i started having plroblems.... i tried a few things even replacing the speedometer, the speedomerter cable and double checking that the cable is well conected to the tranny i still can get my speedometer to work,.. im almost 100% sure its not electrical . so what are the chances on the speed sensor going out??? ..... if it happened to be bad, can i use one fom a D series tranny?
Old Jan 25, 2006 | 04:35 PM
hotboxedcrx's Avatar
Default Re: speed sensor? are b and d series tranny the same? (jccrxtuner916)
Your speedo is mechanical, not 100% electrical... like the newer hondas.
How do you describe your problem?
Possibly your gear on the speedo is stripeed, or the cable is not insterted all the way, aside from that I'd guess you forgot to replace teh c-clip which keeps the cable from backing out.
Modified by hotboxedcrx at 9:27 PM 1/25/2006
Old Jan 25, 2006 | 05:10 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: speed sensor? are b and d series tranny the same? (hotboxedcrx)
The speedometer is mechanical but there is also an electrical
portain to it..
The ECU determines vehicle speed via electrical pulses
through the speed sensor located inside the speedometer:
Pull the cable out of the housing and make sure it is still in one piece.
Picture of connection on a D series speed sender:
https://honda-tech.com/zerothread?id=1325930
Old Jan 25, 2006 | 10:46 PM
the cable that goes from the back of the speedometer has been replaced twice and also the clip is on place,..... that striped gear theory sounds like is gonna be the issue.... i think im just gonna have to take it out and go from there.. now once is out if its strped then can i use a D series one? or does is have to be from a b series tranny?
Old Jan 26, 2006 | 01:28 AM
Pee Wee's Avatar
Default Re: (jccrxtuner916)
YES! i have been using a d16 vss for over a year now in my b16 tranny
Old Jan 26, 2006 | 07:09 AM
Twilight's Avatar
Default Re: (EF8opey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">YES! i have been using a d16 vss for over a year now in my b16 tranny </TD></TR></TABLE>
I think that was the answer for question. And it was a fifth or sixth post.
Old Jan 26, 2006 | 07:48 AM
crxtreme89h's Avatar
Default Re: (Twilight)
Something I wrote recently in another Post. You may know most of this already, but it might help solve your problem.
It's kinda tricky if you don't know what you are doing. You have to pull back the outer shielding until you have exposed the cable and it's metal housing (looks sorta like a big pen in a way). With the shielding pulled back slide the the tip of the cable back into the "PEN" and slide the cable into the VSS in the transmission. Now pull the shielding back over the "PEN" and you should be set, once again provided therein lies the problem and there is nothing wrong with the cable and that it is plugged into the back of the Cluster in the interior of the vehicle.
Here's a picture of the VSS plugged in the transmission:
EDIT: Thanks to 88DXCRX
Modified by crxtreme89h at 9:53 PM 1/19/2006
Modified by crxtreme89h at 9:54 PM 1/19/2006
Pictures taken from this link:
Old Jan 26, 2006 | 08:50 AM
aight then cool thakns guys.. now what made me think is that i have a nohter post about my vtec not workking.. and i was amazed to hear that if your speedo is not working then vtec is also not going to work... anybody has input on that.. thank you.
Old Jan 26, 2006 | 08:54 AM
Pee Wee's Avatar
that is correct. if you speedo is not working, no vtec
Old Jan 26, 2006 | 05:50 PM
after changing the vss frommy dseries tranny.. i come to ind out that is off. by off i mean that im doing lets say 50.. and only reads like 30... what could it be? oh ya.. BTW still no vtec.. (still have 8 blinks)
Old Jan 27, 2006 | 08:27 PM
anybody???
Old Jan 27, 2006 | 09:48 PM
civic889802's Avatar
how do i remove the vss off a d series engine i tried n its hard some one tell me thanks
also i took the vss off a civic but it was electrical n the gear was smaller so it woulnt work but some one tell me how take it out
Old Jan 29, 2006 | 09:33 PM
i replaced the VSS and now the speedometer works... but does not give me the right speed....and now i got code 17???
Old Jan 30, 2006 | 07:52 AM
Pee Wee's Avatar
https://honda-tech.com/zerothread?id=1404128
88_hatch_ls
Sep 4, 2013 05:47 AM
hoga113
Mar 8, 2013 04:32 PM
Runnerdown
Jul 6, 2007 04:05 AM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
foesicks
May 6, 2003 12:17 PM
