car will not start *help*
Old Jan 24, 2006 | 02:25 PM
pip9's Avatar
Default car will not start *help*
i just bought a 95 hatch. it drove home last wednesday. It started on the weekend, but today when i go to start it up nothing.
it doesnt crank at all
battery is good (load tested it, and swaped it out with a known good battery, jumped it with another car just for the hell of it)
i dont hear the fuel pump come on
the rad fan comes on when the clutch is down and i turn the key to start
sometimes the lights on the dash flash and make a buzz noise with the key on (srs light is on w/key on, but was on before, brake light is on w/key on
replaced the main relay
replace ign switch
checked all the fuses
plugged in another ecu
what else do i need to check??
Old Jan 24, 2006 | 03:14 PM
pip9's Avatar
Default Re: car will not start *help* (pip9)
there no cels either
Old Jan 24, 2006 | 04:19 PM
turtles_civic's Avatar
check to see if your starter is getting pos. if its not prob a shorted wire or blown fuse etc. and if it is then run another ground wire strait from the bat. to the starter case(where theold ground is located). if it doesnt start then it might be your key switch
Old Jan 25, 2006 | 07:42 AM
pip9's Avatar
Default Re: car will not start *help* (turtles_civic)
I solved it late last nite. I removed the tranny ground cable on the weekend b/c i was replacing a worn reverse light switch. I just forgot to hook it back up. so everythings better now. thanks tho.
Old Jan 25, 2006 | 09:38 AM
orientalgunz_00's Avatar
haha...i was just gonna post tranny cable cause same thing happened to me...glad you found it...
EFjoe91
Apr 30, 2014 05:49 AM
Pockets
Dec 19, 2007 05:24 PM
cbstudd77
Dec 20, 2006 07:40 PM
rodvang
23
Nov 5, 2005 05:57 PM
MonkeyMagic
Apr 30, 2005 03:08 PM
