just installed an h22 and drove for a week and now it wont start. help!
hey guys i have a 93 sol and just put in a jdm h22 swap in it about a week ago and it was prewired and setup from another eg so it was a direct drop in. well the car ran fine except sometimes it would backfire when im in a high gear and give it full throttle. it ran like a beast when it wouldnt do that but ran a little rich. then one day i drove to my girls and the next morning the car would not start. all it does is turn over. I get spark, fuel, timming is correct, wiring seems correct and plugged up right, no check engine lights also the compression is perfect. The plugs are new, spark plugs are new, cap and rotor are new.. and the thing still wont start. Does anyone know what else I should look for? I was told it was a bad ecu but then there would be a check engine light for that. The ecu is a skunk2 chipped ecu that worked perfectly fine before. Well if someone can help that would be great. Thanks in advance!!
peter17212
10
Feb 8, 2008 04:48 PM
solsi2000
Feb 2, 2006 09:17 PM
eg6turbo
Feb 12, 2005 12:24 AM
