Car leaks only when parked uphill?
are you sure its oil? it could be a loose oil pan bolt on the rear side, why don't you jack up the car from the front and see if it leaks again, or where it leaks from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">Both of those would leak all the time.
Look under the car and see where there is a buildup of oil. It isn't that difficult.</TD></TR></TABLE>
yeah if it only leaks when parked facing uphill check for any cracks in the back of your oil pan you might have caught a rock or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">new oil pan, oil pan gasket & honda bond = no oil leaks
unless you have leaks elsewhere.</TD></TR></TABLE>
Or just look under the car and find the leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 »</TD></TR><TR><TD CLASS="quote">could it be a rear main seal?</TD></TR></TABLE>
That would leak most of the time too. Guessing and throwing parts at something doesn't fix it. He just needs to look for the leak.
