!!!!!!!!NEED HELP!!!!!!!!! please any1
well check it out im doing this daul point DX CRX to 4 injectors with a B16A motor the wiring for the whole conversion is perfectly right i even double check tripple check just to make sure ok here is the problem it cranks, i get fuel, i get spark, and the timming is on point
but for some reason it doesnt crank over it just wouldnt start
well if any1 can help me or give me some suggestion of wat can be the problem let me know ASAP
i been on this thing for like 3days st8
thanx to everyone who can help me i've done this so many times and never had this problem this is soooo new to me
CAN IT BE THE MOTOR??
Stogy
CAN IT BE THE MOTOR??Stogy
If you motor turns over, gets spark, gets fuel and everything such as wiring and other components are right, you have a dud motor with no compression.
If it turns over and something is off, such as wiring and spark, well it just won't catch.
If it not turning over, you might have a dead starter.
Actually, come to think of it, if your dumb like I was and you forgot to reconnect the grounds and your engine wasn't grounded the starter will not turn over...hehe...woops.
Do a compression test then...my first SOHC ZC in my 88 EF sounded like it had compression. He told me the main relay was dead and that's why it wasn't catching, no fuel. So I paid 150$ for it, complete swap. We put it in my brothers EF sedan for now, and when we went to crank it, nothing. Then we did compression test. Was reading nothing in 3 of the 4 pistons haha...I got my money back and got the block melted down for 30$!
it sounds Very possible you have switched the two white wires on the dizzy plug on to me. cranks over just fine but wont start so go out and swap out the two white wires on the dizzy plug and see what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 »</TD></TR><TR><TD CLASS="quote">it sounds Very possible you have switched the two white wires on the dizzy plug on to me. cranks over just fine but wont start so go out and swap out the two white wires on the dizzy plug and see what happens.</TD></TR></TABLE>
dawg everything you can think of i tripple check.....just think bout doin compression test now
are you saying your compression is 48,100,100,170? cause yes that is one major problem then. whatever cylinder has 48 psi of compression either has some messed up valves or no more piston rings. and 100 psi on a b16 isnt good either. 170 is about right.
bucknastty
Jan 15, 2012 12:49 PM
and everything i said up there perfect
