Timing Help Please!
Here's the pics of the cam gears and the crank pulley. I just need confirmation that the timing belt is off. To get it correct, all I need to do is move the crank so that it is aligned with the crank/cover marking correct? Please confirm that what I am doing is accurate and correct. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman »</TD></TR><TR><TD CLASS="quote">Make sure your cams are TDC first. Their not in your pic.</TD></TR></TABLE>
from the looks of it id say you crank is off a few degrees and your exhaust cam is off about a tooth.
just spin the crank to tdc...then remove the belt from the cam gear and line them up and put it back on and re-tighten it to spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabig1(2) »</TD></TR><TR><TD CLASS="quote">the timing marks on our accords are on the flywheel, not the crankpullies.</TD></TR></TABLE>
Thats not an accord engine though
the a b-series vtec engine there buddy...lol
96hatchBoy
Mar 17, 2013 09:25 PM
goota
Aug 22, 2009 07:38 AM
