How do I add A/C to B series Swap?
just to clear something up for me.
First I was told p54 Ac bracket from a delsol and you can bolt the same compressor from your sohc motor.
Then i was told p55 bracket and a bseries compressor?
Anyone with experience what is the right way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 »</TD></TR><TR><TD CLASS="quote">not sure about the p55 but I know the p54 works because that what I'm using know .. you'll also need the tensioner pulley and bracket stuff</TD></TR></TABLE>
Yes, del sol AC bracket...i'm using it too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinkMaggit »</TD></TR><TR><TD CLASS="quote">Del sol AC bracket and SOHC ac compressor? just to make sure</TD></TR></TABLE>
Del sol bracket, SOHC pulleys,belt and compressor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDej2. »</TD></TR><TR><TD CLASS="quote">
Del sol bracket, SOHC pulleys,belt and compressor.</TD></TR></TABLE>
he is going to need the bracket that holds the pulley because the d-series won't work
i have a b series a/c compressor and motor i swapped into my EG civic. my civic compressor is bad so i am wondering what are my options to get the B series compressor working in there?
EJ8 GSR-T
46
Sep 17, 2009 06:47 AM
Propulsion
Aug 12, 2002 10:13 PM
