jacking points... did i screw up someones car?
Old Jan 21, 2006 | 12:19 AM
unrefined7's Avatar
Default jacking points... did i screw up someones car?
the circle in red is where i placed my jack under to lift a del sol. where the LCA bolts to the subframe. is it bent or am i fine?
Old Jan 21, 2006 | 12:25 AM
riceburnerryan's Avatar
you should be fine, but a good place to jack the car up is on the tow hook by the rear bumper... and in the front i would say in the center of the radiator support
Old Jan 21, 2006 | 12:33 AM
97spooncivic's Avatar
Default Re: (riceburnerryan)
dont lift your car there anymore. there are tabs where the jack is supposed to be placed in the front and on both sides
Old Jan 21, 2006 | 03:29 AM
impound's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine, but a good place to jack the car up is on the tow hook by the rear bumper... and in the front i would say in the center of the radiator support</TD></TR></TABLE>
I used to put my car up on the radiator support tab......until it buckled....use pinch welds
Old Jan 21, 2006 | 06:23 AM
93civic_sedan's Avatar
I use the tabs by the wheels.
Old Jan 21, 2006 | 07:01 AM
nsxmatt's Avatar
Default Re: (93civic_sedan)
There are 4 jacking points on either side of the car under the rocker panel front and rear. The radiator support is a big no no. It is way too thin to support 60% of the weight of the car which is what you are doing. The tow points can also be used to jack but don't work under the car with it supported there since it's not a stable jacking point.
Old Jan 21, 2006 | 07:13 AM
Stars's Avatar
I'm a Jackass
Default Re: (nsxmatt)
well... wait did you ask if its bent or not.. just look.. the sheetmetal isn't very thick, might have bent it.. just go look.
Old Jan 21, 2006 | 08:13 AM
unrefined7's Avatar
it's thin... i'm gutted... and it doesn't look bent. there's a bolt there so i figure it would've been fine. i had to because my jack only lifts so high and that was the lowest point. i'm on 4 jackstands right now at the 4 correct spots.
Old Jan 21, 2006 | 09:04 AM
ian.'s Avatar
Default Re: (97spooncivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97spooncivic &raquo;</TD></TR><TR><TD CLASS="quote">dont lift your car there anymore. there are tabs where the jack is supposed to be placed in the front and on both sides</TD></TR></TABLE>
billybod
Jun 21, 2019 08:29 AM
hotimportcrx
27
Jun 24, 2005 06:15 PM
nasaalien
Jun 15, 2005 07:47 AM
eg6T
Sep 1, 2004 12:38 PM
WTypeRogerX
Jun 14, 2003 11:25 AM
