Jack Points
Old Apr 4, 2003 | 03:44 AM
WTypeRogerX's Avatar
Default Jack Points
Can someone tell me the proper places (other than the 4 rail corners since you can't fit both a jack and stand there) to jack up the R or put jack stands? Pictures or diagrams would be even better.
Old Apr 4, 2003 | 04:55 AM
Batoutahell's Avatar
Default Re: Jack Points (WTypeRogerX)
Jack on the rear tow hook and the front lower radiator support. Jackstands go on the 4 rail positions.
Old Apr 4, 2003 | 04:59 AM
Floyd's Avatar
Default Re: Jack Points (Batoutahell)
In order to do this properly, you will need a jack with enough lift height to raise the car up from the tow hook high enough to get the jack stands under the 4 corners. If you don't have a full sized jack, you can use some boards under the jack to get some extra lift.
Old Jun 13, 2003 | 11:56 PM
Default Re: Jack Points (Floyd)
You should probably put a board under the radiator support and tow hook to protect them from the jack. I do that with my WRX which you have to jack up under the rear differential.
Old Jun 14, 2003 | 11:12 AM
type r 01-1063's Avatar
You can jack from the front (2) tow hooks.
Old Jun 14, 2003 | 11:25 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WTypeRogerX &raquo;</TD></TR><TR><TD CLASS="quote">You should probably put a board under the radiator support and tow hook to protect them from the jack. I do that with my WRX which you have to jack up under the rear differential.
you're not going to damage them. hell my rad support is far more damaged from scrapping parking curbs (or whatever those 8' wide things are called) than from any jack.
billybod
Jun 21, 2019 08:29 AM
hondachris1994
17
Apr 9, 2006 07:14 AM
RACEPAK
37
May 5, 2005 03:19 PM
vtecnik
Dec 14, 2004 12:05 AM
Mike813
May 27, 2003 06:07 AM
