TECHONE HID installation troubles...8(
Wire one hid at a time.. make sure that the ground wire is a good ground.. you may want to not use the factory wireing grond, and just run your own.. also run relays.. try that then let us know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Wire one hid at a time.. make sure that the ground wire is a good ground.. you may want to not use the factory wireing grond, and just run your own.. also run relays.. try that then let us know</TD></TR></TABLE>
thanks, i got it to work. I posted the correct diagram picture above too for future reference to H4 owners! 8)
how do a install low beams on my 2000 hatch? i have hids from a bmw and every body keeps flashing their high beams at me as if i have mines on. they are alittle bright. i am not good with electrical so can some one explain to me? the diagram is alittle hard to understand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay-d-em »</TD></TR><TR><TD CLASS="quote">how do a install low beams on my 2000 hatch? i have hids from a bmw and every body keeps flashing their high beams at me as if i have mines on. they are alittle bright. i am not good with electrical so can some one explain to me? the diagram is alittle hard to understand.</TD></TR></TABLE>
its probably because you are using HID's in a housing ment for halogen bulbs....this creates scatter and blinds everyone, all over the place....you need a headlight with a projector and a OEM HID projector from a car in order to make it work well with a retrofit, if not, it scatters, everyone is blind and just wait until you blind a cop and get a ticket, or worse, blind someone that already isnt good at driving and have them swerve into you
do it right or die (could be litteral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">
do it right or die (could be litteral)</TD></TR></TABLE>
u explained it perfectly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev2Eight_EM1 »</TD></TR><TR><TD CLASS="quote">get this https://www.casperselectronics...ode=
Then adjust aim as needed </TD></TR></TABLE>
i have those and never used them. i did my own retro fit. i am gonna try those out. thanx!
