CEL code 41...!!
Old Jan 20, 2006 | 02:04 PM
bmiller17's Avatar
Default CEL code 41...!!
could someone show me or tell me where the Primary oxygen sensor heater is located please?
Old Jan 20, 2006 | 03:28 PM
Ninety5Ex's Avatar
Default Re: CEL code 41...!! (bmiller17)
The one on the header in the front. The heater is a part of the sensor.
Old Jan 20, 2006 | 04:39 PM
thisisntjared's Avatar
the other guy said where it is but that may not be the issue. have you dont any mods recently?
Old Jan 20, 2006 | 05:03 PM
Haltom Hatch's Avatar
basically your car sees that the power circuit going to the o2 sensor is not correct. bad ground no power or whatever. first check to make sure that the o2 wires are not pinched broke cut torn or disconected. if there isn o problem check even closer to the ecu in the wire harness. If it continues just replace the the o2 sensor.
Old Jan 20, 2006 | 08:11 PM
bmiller17's Avatar
Default Re: (Haltom Hatch)
okay, ill check all of that in the morning, i bet that one of the wires came out of the plug
bobcollege
15
Mar 22, 2018 10:12 PM
chiefrocka
May 18, 2009 04:11 PM
pr_tony_montana
14
May 21, 2005 01:25 PM
96tegls
Jan 7, 2005 09:59 PM
bOOsTiNSoHcVtEc
Jun 6, 2003 09:30 PM
