cel code 41
Old Jan 7, 2005 | 11:20 AM
96tegls's Avatar
Default cel code 41
i checked it out what is primary o2 sensor heater. i dont understand someone help me out here please
Old Jan 7, 2005 | 12:05 PM
JimBlake's Avatar
Default Re: cel code 41 (96tegls)
The sensor doesn't work until it gets hot, so there's a preheater built into it. That gets it going much faster vs. just waiting for the exhaust to heat it up.
There should be 2 same-color wires coming from the sensor. Those are the heater wires, you should measure 10 to 40 ohms between them, & neither one should have any continuity to ground. If that's not OK then buy a new sensor.
If that's OK, then you can troubleshoot the heater power circuit. I think it gets its power from the main relay. Maybe a wire is disconnected somewhere?
Old Jan 7, 2005 | 09:59 PM
96tegls's Avatar
yea my o2 had a small splice for some reason when i looked at so thats my conclusion thanks for your help
98ej8coupe
Apr 24, 2007 05:22 AM
bmiller17
Jan 20, 2006 08:11 PM
BeavisB16
Apr 29, 2005 03:57 PM
senpai
Jan 12, 2003 01:24 PM
