Rear disk e-brake question
Old Jan 17, 2006 | 02:03 PM
l2agnar0k's Avatar
Default Rear disk e-brake question
I have read a lot of post and it seems it varies from post to post i even ask stackz(guy tat wrote the DIY) still confused...
ok can u use 99-00 e-brake cables on integ rear brakes?
Old Jan 17, 2006 | 02:22 PM
CRXb18Turbo's Avatar
Default Re: Rear disk e-brake question (l2agnar0k)
depends on the car...
Both cable should work if they are from a disc.
The SI is shorter than the Teg one...
Go figure.
Old Jan 17, 2006 | 03:27 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Rear disk e-brake question (CRXb18Turbo)
Wanna tell us what car this is going on? On a EG, feel free to use the Teg cables. on a EK, yea use the 99-00 Si e-brake cables, they attach the same to the teg rear brakes cause the teg and Si calipers are similar.
Old Jan 17, 2006 | 03:51 PM
Syndacate's Avatar
They should work because there's a lil slack even in the shorter model (in width) like the si (I'm pretty sure), not positive (never done it) gl on it tho
same thign as CRXb18Turbo said
but I still think it'll fit.
Old Jan 17, 2006 | 05:00 PM
johnecon2001's Avatar
When I did my swap in my 99 EK coupe, I used 98 GSR brakes. I used the cables that came with them and they fit fine.
Old Jan 17, 2006 | 06:44 PM
l2agnar0k's Avatar
Default Re: (johnecon2001)
oh they are going into a hatch i know the integ cables would work fine, but si cables are cheaper and i would assume fit perfectly, but i have been told that if u use integ calipers u have to use integ cables
Old Jan 18, 2006 | 01:14 AM
l2agnar0k's Avatar
Default Re: (l2agnar0k)
bumpped
Old Jan 18, 2006 | 01:35 PM
l2agnar0k's Avatar
noone else with anything to add?
Old Jan 18, 2006 | 06:33 PM
l2agnar0k's Avatar
99-00 si cables it is then?
Old Jan 18, 2006 | 07:25 PM
Ls_V_TurboSi's Avatar
When I put 5 lug on my si I had to use si Ebrake cables becuase the teg ones were a little too short. So if you have si cables they should work becuase they seem to be the longest
stivic
May 17, 2007 08:43 PM
undefinedek9
Jan 6, 2006 06:30 PM
xoutlawz00x
Sep 10, 2004 02:54 PM
drunknbass
Mar 18, 2004 03:27 AM
