Rear disk e-brake question
I have read a lot of post and it seems it varies from post to post i even ask stackz(guy tat wrote the DIY) still confused...
ok can u use 99-00 e-brake cables on integ rear brakes?
* B A N N E D *
1 Post
Re: Rear disk e-brake question (CRXb18Turbo)
Wanna tell us what car this is going on? On a EG, feel free to use the Teg cables. on a EK, yea use the 99-00 Si e-brake cables, they attach the same to the teg rear brakes cause the teg and Si calipers are similar.
They should work because there's a lil slack even in the shorter model (in width) like the si (I'm pretty sure), not positive (never done it) gl on it tho
same thign as CRXb18Turbo said
but I still think it'll fit.
Re: (johnecon2001)
oh they are going into a hatch i know the integ cables would work fine, but si cables are cheaper and i would assume fit perfectly, but i have been told that if u use integ calipers u have to use integ cables
Re: (l2agnar0k)
When I put 5 lug on my si I had to use si Ebrake cables becuase the teg ones were a little too short. So if you have si cables they should work becuase they seem to be the longest
undefinedek9
01-06-2006 06:30 PM
xoutlawz00x
09-10-2004 02:54 PM
