Spindle nut
Old Jan 12, 2006 | 08:32 PM
ch00dlz's Avatar
Default Spindle nut
Thx for responding on my last post fellas! I appreciate ya'll!
Anybody have any tips on loosening the spindle nut so I can free the axles? Its kinda rusty down there. Its also about 40 degrees in my garage, but I dont know if thats the problem, my weak *** can't budge s#*t. Air gun ( 90psi max) doesn't budge either!
I apreciate your help!
Old Jan 12, 2006 | 08:44 PM
underb00steg6's Avatar
Default Re: Spindle nut (ch00dlz)
make sure its not bent in the notch to lock it on the axle ....and it should come out with an air gun...
Old Jan 12, 2006 | 08:59 PM
dohcVTECeg2's Avatar
Default Re: Spindle nut (underb00steg6)
impact gun should do the trick
Old Jan 12, 2006 | 09:11 PM
ch00dlz's Avatar
Default Re: Spindle nut (dohcVTECeg2)
Yeah but my impact gun runs only 90 psi max. Let me try again.
Thnx dohcVTEC
Thx boosteg
Old Jan 12, 2006 | 10:51 PM
RedEK9's Avatar
My freind had the same problem earlier this week. This is how I did it!!!
Torque Wrench w/breaker bar extension,32mm socket, Have some one press the brakes, attach the bar, and stand on that bitch till you break the nut off! This took me a total of 2 minutes and voila!!!! Now you can move on!!!
Old Jan 12, 2006 | 11:36 PM
F20Cteg's Avatar
Default Re: Spindle nut (RedEK9)
I hope you never plan on that torque wrench being accurate.
Torque wrenches are not breaker bars. This is how you mess them up.
Old Jan 13, 2006 | 12:55 AM
99blackcivicSi's Avatar
Default Re: Spindle nut (F20Cteg)
get a breaker bar, pop the center cap out, drop the car down, stand on the breaker bar jump whatever you have to do, to get it loose.
all of this is after you unstake the axle nut though
Old Jan 13, 2006 | 01:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Spindle nut (99blackcivicSi)
32mm Impact socket, and a 3ft breaker bar. No problems.
Old Jan 13, 2006 | 05:06 AM
ch00dlz's Avatar
Okay. But when you just dropped the engine in the damper fork and ball joint is already out so that makes this process shitty!
I guess that means put it together for a more secure and sturdy challenge??
Old Jan 13, 2006 | 07:47 AM
gabebauman's Avatar
I slip my floor jack handle over my braker bar and stand on it.
Old Jan 13, 2006 | 03:04 PM
ch00dlz's Avatar
Default Re: Spindle nut (gabebauman)
Nice ride! Hella clean gabebauman!
I just snapped the male peice that the bit attaches to off !
I mean...I'm about 190lbs. I juiced roids for 3 years in college dood ! And this spindle nut don't budge!
Anybody know of any other way?
Old Jan 13, 2006 | 03:26 PM
just Touge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEK9 &raquo;</TD></TR><TR><TD CLASS="quote">My freind had the same problem earlier this week. This is how I did it!!!
Torque Wrench w/breaker bar extension,32mm socket, Have some one press the brakes, attach the bar, and stand on that bitch till you break the nut off! This took me a total of 2 minutes and voila!!!! Now you can move on!!! </TD></TR></TABLE>
WTF....your insane dawg. Tourque wrench death.
Old Jan 13, 2006 | 07:18 PM
transpar_nt's Avatar
Default Re: Spindle nut (TougeSiR)
I use a 24" breaker bar and my arms
Don't even bother with an impact. It took me 15 minutes for ONE nut on ~275 psi. I used the breaker bar with no snipe on the next one and it broke loose with 5 seconds of pulling, and have done it this way since. If you're a pansy () just put a 2-4 foot snipe over the bar and it shouldn't be a problem. Lifting 100lbs with a 10 foor bar will get you 1000ftlbs of torque biotch!!
tkosmith
53
May 2, 2006 08:32 AM
Honda Crx
33
Oct 26, 2005 07:55 AM
6.5inCivic
33
Aug 6, 2002 11:45 AM
SOcalistreetracer
10
Jun 12, 2002 03:37 AM
DragII
Oct 17, 2001 10:42 AM
