need help with my car radio
Old Jan 12, 2006 | 06:56 PM
pkgwjai082's Avatar
Default need help with my car radio
i have a 92 civic 4 door.
just recently my stereo doesnt have any sound. i tried a new head unit and it still doesnt work. there is no sound at all from the speakers but the head unit lights up and everything. theres power going to the unit. the wierd thing is after a few rpm the sound comes in fuzzy then just fades away. Does anyone know what the problem is here?
Let me know. Thanks alot everyone!
Old Jan 12, 2006 | 07:04 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: need help with my car radio (pkgwjai082)
may have a speaker grounding out. somthing is grounding out
Old Jan 12, 2006 | 08:18 PM
pkgwjai082's Avatar
Default Re: need help with my car radio (HybridcivicLS-T)
that wasnt the problem? anyone else? please help. i need the advise
Old Jan 13, 2006 | 04:21 AM
B18C_EJ8's Avatar
How do you know that wasn't the problem? Did you disconnect each speker one at a time?
Old Jan 14, 2006 | 08:52 AM
need_a_h22's Avatar
My friend, that IS a ground problem. Check the chassis ground is making full metal on metal contact (did u scrape away the paint)? Then post results.
Old Jan 14, 2006 | 09:47 AM
pkgwjai082's Avatar
Default Re: need help with my car radio (need_a_h22)
problem solved! thanks guys
Old Jan 14, 2006 | 01:26 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkgwjai082 &raquo;</TD></TR><TR><TD CLASS="quote">problem solved! thanks guys </TD></TR></TABLE>What was it? 94
Old Jan 14, 2006 | 05:16 PM
pkgwjai082's Avatar
Default Re: need help with my car radio (fcm)
the rear left speaker was broken. The positive and negative connections snapped off the speaker.
Old Jan 14, 2006 | 08:38 PM
sony224422's Avatar
well then it was grounding out..
Old Jan 15, 2006 | 09:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: need help with my car radio (sony224422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">well then it was grounding out.. </TD></TR></TABLE> Shorting out yes, not nessessarly grounding out. 94
Old Jan 15, 2006 | 10:47 AM
sony224422's Avatar
yeah your probably right. pos probably touched the ground which would turn the internal amp off.. actually shouldn't it have turned off the head unit? i know on mine if you short out ( touch pos and neg together) it will turn off so nothing gets hurt.
sony224422's Avatar
i just figured it would be a ground from the engine whine..
Old Jan 16, 2006 | 08:03 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">yeah your probably right. pos probably touched the ground </TD></TR></TABLE>
Pos. touched the neg. or "signal return" and the intermitant "sound comes in fuzzy" would be because as the RPM goes up so does voltage and the protection circuit would have to deal with it. 94
DCshoecompany
Audio / Security / Video
Aug 11, 2008 01:22 AM
kelviiv
14
Jan 2, 2008 06:53 AM
pl8rzclub
Sep 24, 2007 04:04 PM
youraquickone
12
Jul 2, 2005 10:04 PM
dizzyroc88
Aug 19, 2004 07:34 AM
