*Deck Problem *AGAIN*!
Old Dec 29, 2007 | 08:35 PM
kelviiv's Avatar
Default *Deck Problem *AGAIN*!
Hello Guys
Recently I posted a topic about my deck not functioning correctly. I recently just purchased another deck and it has the same problem. I tried 2 different decks but I still have the same problem.
*Problem, Only the remote control can function the head unit. The head unit will only allow me to eject and change the source. I can do nothing more than that. I also have to re-insert my face plate every time the car is turned on in order to use the remote.
Things I have done to try to fix this.
- Get a new harness and did the re-wiring together.
- Checked ALL my fuses.
- Try 2 different head units.
Any one have any ideas?
Thanks again.
Old Dec 29, 2007 | 10:10 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: *Deck Problem *AGAIN*! (kelviiv)
what kind of headunit?
Old Dec 29, 2007 | 10:49 PM
kelviiv's Avatar
Clarion
I've tried JVC
and i am not going to buy anymore head units and go return them.
Old Dec 29, 2007 | 11:38 PM
Default Re: (kelviiv)
were are you buying these units from? Do you have a multi meter?
Old Dec 30, 2007 | 09:23 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">were are you buying these units from? Do you have a multi meter?</TD></TR></TABLE> That would be my question also.
Also, what is the MM&Y of car it is in?
It is quite a coincident that 2 diff. HUs would have the same exact problem, much less two diff. brands with the same problem. 94
Old Dec 31, 2007 | 10:27 AM
kelviiv's Avatar
95 integra ls
i am buying my units from best buys/ circuit citys/frys
Old Dec 31, 2007 | 01:13 PM
fcm's Avatar
fcm
Old Fart
Then they would be authorized dealers of the product you are getting so we know they are new HUs.
Are you using a harness adapter, like one of these... http://www.scosche.com/product...D/295 and are you sure it is wired in properly? 94
Old Dec 31, 2007 | 02:52 PM
kelviiv's Avatar
yes it is wired properly
i started getting this problem after a few months of installing a deck
now it is permanent to every deck
weird thing
checked all connections and they are fine.
Old Jan 1, 2008 | 10:50 AM
kelviiv's Avatar
ttttt
Old Jan 1, 2008 | 12:01 PM
fcm's Avatar
fcm
Old Fart
As I said, it is a coincident that you would have the same exact problem with two HUs, same make and model, maybe just a bad run, but a diff. make with the same exact problem is more then a coincident, you would think it has to be something common to both brands, leaving only the install, wiring and physical mounting of the HUs as the common factor.
Only thing I can suggest is to pull the HU and with a multimeter check/confirm that the wiring is correct, that you have a good 12V+ on the acc. and constant leads, that the ground is good, that all 8 speaker leads, [4 sets] are wired properly to the proper speakers and there are no shorts to ground, power or each other on any one of the 8 speaker leads. that the illumination lead is properly caped off if not being used. 94
BTW, Are you using a proper back support on the HU?
What is the MM&Y of the car?
Old Jan 1, 2008 | 12:19 PM
kelviiv's Avatar
95 integra ls as stated above
i've installed many hu's before and i am using the correct harness
i am going to get a volt meter soon and see what is not getting enough power.
Old Jan 1, 2008 | 02:50 PM
fcm's Avatar
fcm
Old Fart
It may be the correct harness, but it may also be pinned wrong, I have seen that more then a few times.
When metering, pay close attention to the speaker leads. 94
Old Jan 1, 2008 | 07:27 PM
kelviiv's Avatar
found 2 dead wires from the car not from the harness
not sure what its called
but all i have to do is replace those 2 wires correcT?
if i'm wrong correct me thanks
Old Jan 1, 2008 | 10:22 PM
what color wires?
Old Jan 2, 2008 | 06:53 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">what color wires?</TD></TR></TABLE>Ditto that, and what do you mean "dead"? 94
br3ak3r84
Honda S2000
Mar 21, 2008 02:07 PM
sleeperteg
Audio / Security / Video
Oct 26, 2005 08:42 AM
youraquickone
12
Jul 2, 2005 10:04 PM
dizzyroc88
Aug 19, 2004 07:34 AM
