tial 38mm wastegate
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 »</TD></TR><TR><TD CLASS="quote">you will get a little higher boost if you pull wastegate vacumm at the manifold but i prefer getting it off the compressor provides good response</TD></TR></TABLE>
my line is hooked up to a nipple that is on the hot pipe before the intercooler. about a foot down from the discharge of the tubine. inot problems here. holds 10psi exactly with a 10psi spring from turbonetics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 »</TD></TR><TR><TD CLASS="quote">right..it will work fine either way
on higher boost situations might be better to connect to the compressor to get around boost spike
</TD></TR></TABLE> and make shure you use a 1/4" I.D. line
on higher boost situations might be better to connect to the compressor to get around boost spike</TD></TR></TABLE> and make shure you use a 1/4" I.D. line
2LiterTurboSeR
Apr 19, 2006 12:33 PM
