Building a z6... what pistons??
Old Jan 11, 2006 | 05:52 PM
mike93eh
Guest
Posts: n/a
Default Building a z6... what pistons??
im building my spare d16z6 and ive decided on eagle h beam rods and oem bearings, but cant decide on which pistons to go with. there are so many....CP, Arias, SRP, Vitara, Wisesco, JE...ETC.
i want something affordable, easily available, something close to 9.0:1 CR, and can hold up to at least 300-350whp. and ones that dont need machined to fit eagle rods.
Old Jan 11, 2006 | 05:53 PM
redzcstandardhatch's Avatar
something different
Default Re: Building a z6... what pistons?? (mike93eh)
if you have stock sleeves, SRPs are the cheapest, and they are stronger than your stock sleeves. i love my SRP's and plan on running around 20 Psi (rich and conservative tune) through them this year. currently at a rich 16 psi. REALLY REALLY pulls.
Old Jan 11, 2006 | 05:57 PM
mike93eh
Guest
Posts: n/a
Default Re: Building a z6... what pistons?? (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">if you have stock sleeves, SRPs are the cheapest, and they are stronger than your stock sleeves. i love my SRP's and plan on running around 20 Psi (rich and conservative tune) through them this year. currently at a rich 16 psi. REALLY REALLY pulls. </TD></TR></TABLE>
yea stock sleeves..about how much are srp's? i heard alot of crap about srp's but will they hold 300-350whp safely?
Old Jan 11, 2006 | 05:59 PM
something different
with a good tune, yeah.
jeff evans has made 308 whp on a stock bottom end, and supposedly the guy is daily driving it.
Old Jan 11, 2006 | 06:01 PM
mike93eh
Guest
Posts: n/a
Default Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">with a good tune, yeah.
jeff evans has made 308 whp on a stock bottom end, and supposedly the guy is daily driving it. </TD></TR></TABLE>
yea that **** is just nuts! wonder how long it will last though?
Old Jan 11, 2006 | 06:05 PM
something different
any detonation at the level, and it'd die.
obviously jeff evans knows his ****! haha. SRP's are so much stronger than stock, its funny. if they cant hold the same or slightly higher power level, that sucks.
Old Jan 11, 2006 | 07:47 PM
z6's Avatar
z6
vitara
Old Jan 11, 2006 | 08:09 PM
turboeg77's Avatar
Default Re: (z6)
if had the money id go for CP's , Endyn or Wiseco
I got SRP's gonna boost it around 18psi on stock posted sleeves
I have seen vitaras boosted at 15psi so i assume that the SRP's can take 20psi.
Old Jan 11, 2006 | 08:17 PM
mike93eh
Guest
Posts: n/a
Default Re: (turboeg77)
then srp's should be good for my goals..
anyone know where i can get a deal on srp's?
Old Jan 11, 2006 | 08:18 PM
splitime's Avatar
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">vitara </TD></TR></TABLE>
If you are really looking for budget... go vitara. I'm using them, have over 7k miles on them and they are noisey but holding fine so far.
If I blow these... I'll be going with a set of wiesco though. It really all depends on the $$ you are willing to put down.
Old Jan 11, 2006 | 08:22 PM
mike93eh
Guest
Posts: n/a
im not feelin vitara's
something different
my SRP's were very cheap....i got them from cody @lovefab.
i had vitaras, and i was going to install them, then i just decided to go all mostly all out.
Old Jan 12, 2006 | 08:25 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">
yea stock sleeves..about how much are srp's? i heard alot of crap about srp's but will they hold 300-350whp safely?</TD></TR></TABLE>
There are people who have made 400+whp on SRP's perfectly fine.
Old Jan 12, 2006 | 09:38 AM
ladysman's Avatar
Default Re: Building a z6... what pistons?? (RyanCivic2000)
Mike must have been a bad boy cause it looks as though he is banned..
Old Jan 12, 2006 | 09:47 AM
Everyones Hero's Avatar
I didn't know there were problems with SRPs.
I'd stay away from Vitaras. For my 300-350whp build I'm going to use eagle H-Beams with either Arias or SRPs.
I don't see the point in getting Vitaras. They're undersized so you get blowby and tons of noise. I'd like to see the sleeves of a Z6 after a set of Vitaras has been run for awhile.
Old Jan 12, 2006 | 11:58 AM
beerbongskickass's Avatar
Default Re: (z6)
Yeah I dunno about that. 300-350whp might be a little much for those cast pistons. What's the most anybody has even made on those on a daily driver? Has anbybody even hit 300whp? I sure as hell wouldn't want to run 350whp on those Vitara's lol...
Do it right the first time and get some nice forged pistons.
CP, Wiseco, Arias, etc... your choice really.
Old Jan 12, 2006 | 12:00 PM
Default Re: (beerbongskickass)
I haven't seen any hp numbers from people running Vitaras. They say "I'm running 20 pounds of boost!"
Great, what kind of numbers are you putting down?
Old Jan 12, 2006 | 12:35 PM
splitime's Avatar
Default Re: (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">I haven't seen any hp numbers from people running Vitaras. They say "I'm running 20 pounds of boost!"
Great, what kind of numbers are you putting down?</TD></TR></TABLE>
FJT posted his numbers...
When I get some I'll post numbers...
I've got over 7k miles on mine and going fine...
My new setup should be quite capable for what it is... of making good power... I'm going to see what the Vitaras can handle.
SpoolnByYou
Dec 19, 2005 02:28 PM
the.hamburglar
Sep 29, 2005 05:59 AM
infinatenexus
Feb 26, 2004 06:32 PM
Jer Del Sol
Nov 10, 2003 10:35 AM
Turbo Laser
May 25, 2002 04:24 PM
