checking cels and srs blinks
Old Jan 11, 2006 | 02:51 PM
egcivic's Avatar
Default jumpy idle after swap
i just swapped in a d15b7
andim getting a check engine light
so im trying to check my check engine light
and i follow the instructions and hook up the jumper and the check engine stays on and the srs light blinks
the problem is that my idle is smooth but it idles really high and sounds liek there really isnt a limit on it, almost like its accelerating
everything else seems fine
Modified by egcivic at 1:12 PM 1/14/2006
Old Jan 11, 2006 | 07:02 PM
egcivic's Avatar
Default Re: checking cels and srs blinks (egcivic)
bump cause i gotta go back to college
Old Jan 13, 2006 | 06:57 PM
egcivic's Avatar
anyone?
Old Jan 13, 2006 | 07:03 PM
95DxSi-R2
Guest
Posts: n/a
wow, niccccccccccce, just for the hell of it, check the blinks on the srs light. did u swap harness'?
Old Jan 13, 2006 | 08:36 PM
egcivic's Avatar
Default Re: checking cels and srs blinks (95DxSi-R2)
no im using the same harness and i looked under the steering column and everything looks like its hooked up
i searched and it looks like other ppl had this problem before and there was no decisive answer
also when i turn on the car the srs light doesnt stay on
and the problem is my car sounds liek it is accelerating while at idle
so is it the tps?
Old Jan 13, 2006 | 08:48 PM
95DxSi-R2
Guest
Posts: n/a
what is it idleing at? (rpm)
Old Jan 14, 2006 | 07:28 AM
egcivic's Avatar
i dont have a tach :/ but judging by the sound it sounds liek its almost going to redline or getting pretty high up there
Old Jan 14, 2006 | 07:51 AM
egcivic's Avatar
so i jus tried the tps sensor off my old car.. (er the iacv whatever it is) and it fixes the revving and now i have a jumpy idle.. which means that i hacve a vacuum line off i beleive?
MACSI360
Honda Civic (2001 - 2005)
Mar 3, 2011 05:12 PM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
thunderboy
Mar 9, 2008 09:49 PM
Devious951
May 29, 2007 04:43 PM
2000si
May 9, 2005 01:16 PM
