hesitation at low rpm and back fire
Old Jan 10, 2006 | 09:43 PM
yz125rider21's Avatar
Default hesitation at low rpm and back fire
I have freaking done everthing and still hesitates and back fires...I change spark plugs,oil,gas added octane...checked the tdc and the timing all seems to be perfect...but my car still seems to hesitate and is not throwing any codes....what else could it freaking be....
Old Jan 10, 2006 | 11:02 PM
035psi's Avatar
Default Re: hesitation at low rpm and back fire (yz125rider21)
if you have been using NOS mannnnnnnnn... maybe thats it !!! or maybe your not getting any fuel (i.e. need new fuel pump, or maybe a upgraded fuel system is needed..) what do your plugs look like ?
Old Jan 10, 2006 | 11:14 PM
I havent used nitrous on this motor they stole the kit right after I dropped in a new motor 9 months ago...I am getting fuel I took of rail to make sure...I just cant figure this out..i am about to take it and get is dianostic on it but I hate to fork out that money
Old Jan 10, 2006 | 11:35 PM
035psi's Avatar
Default Re: (yz125rider21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">I havent used nitrous on this motor they stole the kit right after I dropped in a new motor 9 months ago...I am getting fuel I took of rail to make sure...I just cant figure this out..i am about to take it and get is dianostic on it but I hate to fork out that money</TD></TR></TABLE>
that doesn`t mean anything you have to check your fuel Pressure while it is operating w/ the fuel pump on... and if you look at your plugs they could tell you a whole lot...
Old Jan 11, 2006 | 12:16 AM
plugs are fine...I got new ones now...how i check the pressure for fuel???
Old Jan 11, 2006 | 12:51 AM
035psi's Avatar
what did your old plugs look like ?
to check your fuel pressure you need a gauge, the guage mounts into the top of the fuel filter
- remove the service bolt, while holding the bango fitting in place
-attach the fuel pressure gauge
-** Start the engine- measure the fuel pressure with engine idling and the vacuum hose of the fuel pressure regulator disconnected from the fuel pressure regulator and pinched...
if you tell me what engine you have i could possibly findout what the required pressure is..
Old Jan 11, 2006 | 01:24 AM
paopao's Avatar
Default Re: (035psi)
Check the firing order, sometimes simple mistakes can be made. Grounds too.
Old Jan 11, 2006 | 01:45 AM
I have a d16a6 in it...well I have to get a fuel pressure tester tomorrow I only have a compression tester...
Old Jan 11, 2006 | 01:46 AM
plugs where a brownish color...but the gaps where bigggg...so I got new plugs and gap them to .041...cant think what else would be causing all this
Old Jan 11, 2006 | 06:50 AM
jlicrx's Avatar
is camshaft timing correct?
Old Jan 11, 2006 | 10:04 AM
035psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">plugs where a brownish color...but the gaps where bigggg...so I got new plugs and gap them to .041...cant think what else would be causing all this</TD></TR></TABLE>
if your plugs were brown you were leaning out.. check your fuel pressure i`ll look the specs up before the end of the day. it sounds as if you have a poorly chipped ecu/ tuned S-afc, or a bad fuel pump..
Old Jan 11, 2006 | 02:05 PM
035psi's Avatar
the fuel pressure should be at 35-41psi (240-279 kPa)..
-if the pressure is less than specified, check for:
--clogged fuel filter
--clogged or leaking fuel lines
--pressure regulator fail (do you have a adjustable FPR ?????? it may be out of adjustment )
-if is higher than specified check for
--pinched or clogged fuel return hoses or pipes
--pressure regulator failure
if your fuel system is in proper order check you MAP sensor next, if that is good... check your ignition system...
and DO- it in that order of process of elimination, or you could be fixing things that are in working order only to find out your skipping something.
Old Jan 11, 2006 | 02:30 PM
mar778c's Avatar
Community Builder
Community Influencer
good advice
Old Jan 11, 2006 | 03:10 PM
ya I have to pick up a pressure gauge....I just put a new filter on it though....
Old Jan 11, 2006 | 05:01 PM
MonkeyMagic's Avatar
its a bad o2 sensor.... almost guarantee
the only things that could cause those symptoms are:
o2s (thru 2-4K rpms)
map sensor
unless you have some rare expletive up.. but i doubt it
Old Jan 11, 2006 | 06:55 PM
I will be buying a o2 and and i check on that map sensor....I HATE ******* THIEFS..car ran great till it was stolen....
Old Jan 11, 2006 | 09:18 PM
Hey what would cause backfire out of the intake???...thats where it is coming from...we just timed it and everything and still getting bad backfire out the intake and hesitation on motor....also where can I get a fuel pressure tester at???my friend brought one over but wouldnt work with my honda...
Old Jan 11, 2006 | 09:45 PM
035psi's Avatar
Default Re: (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">its a bad o2 sensor.... almost guarantee
map sensor
unless you have some rare expletive up.. but i doubt it</TD></TR></TABLE>
and what is your reasoning for it being an o2 sensor?
you can pick up a fuel pressure ( tester) gauge at any generic autoparts store for cheap..
make sure your MAP sensor, and TPS sensor wires are not switched.... and i`m not sure if the the idle control valve wires can reach the IAT sensor (on a D-series) but, make sure those two are not swtched also..
if you bought a Ohm meter and a helms it would take you 15mins to find the poblem with their process of elimination procedures..
Old Jan 11, 2006 | 09:56 PM
they are all in right spot....but can I get a diagram on vacuum lines to it all....
Old Jan 12, 2006 | 04:29 PM
I am literally having no luck with finding a fuel pressure tester here in my town...anybody have a pic what the fitting looks like...cause my friend has a gauge tester but not the right fitting for imprts....
Old Jan 12, 2006 | 11:58 PM
BaYoNAiM's Avatar
bump???
im having the same problem on my zc single...
i have no low end power and it bogs, but anything after 3k its pure power...
i changed my o2 still no difference...
the guy at autozone suggested cap and rotor replacement which i have not yet done...
i had a friend tell me that he had the same problem and it fixed itself after 3 weeks...
hopefuly someone here can give us the cure...
Old Jan 13, 2006 | 12:12 AM
Default Re: (BaYoNAiM)
hey have you smog th zc in cali yet?....i havent but once car problem is fixed i am do for smog...I was told zc is legal in cali and passes smog...so it better past smog and not have to deal with a freaking ref lol....i will kill my ref in my town he a major ********
Old Jan 13, 2006 | 10:45 AM
BaYoNAiM's Avatar
bump?
Old Jan 13, 2006 | 11:15 AM
HiProfile's Avatar
Well lets assume that when it was stolen, it was redlined a few times. Lets assume that they possibly floated (and bent) a valve or three. So... have you tried a compression test? Leakdown test? A bent valve could definately let the engine backfire, since the intake manifold is essentially open to the cylinder when it fires.
The other issue, as said, could be the o2, or leaning out. When I was in the process of tuning uberdata, I had an odd lean spot around 2.5k. It was spuratic since when cold, it wouldn't correct using the o2, and sometimes it wouldn't corrct due to extra load. It would stutter, but not backfire. Backfiring into the exhasut is a rich condition usually, fyi. Adding octane booster won't help if it's getting too much or not enough fuel.
Also, when I put my 780's in, simple scaling wasn't enough, so it was running 15-17:1 air-fuel ratios till I added fuel. I bucked along like a mechanical bull.
ALso check your coil, they have a tendency to either die instantly, or slowly. At the very least, check in the dizzy cap for orange dust, signifying a dying dizzy bearing (that heat kills the sensors).
Old Jan 13, 2006 | 11:19 AM
jlicrx's Avatar
[QUOTE=yz125rider21]Hey what would cause backfire out of the intake???...QUOTE]
camshaft timing wrong
Azn Kenny
May 14, 2006 08:32 PM
91whiteZCrex
Apr 30, 2006 04:37 PM
Griff
Jun 14, 2004 07:31 PM
Bowen
Nov 12, 2003 04:38 AM
RideAposition
Jul 13, 2003 10:32 PM
