Eg With swaps.... can you still use a full catback exhaust system without having to ajust the pipein
Old Jan 9, 2006 | 11:36 PM
Kangolbrand's Avatar
Default Eg With swaps.... can you still use a full catback exhaust system without having to ajust the pipein
i got a 92 with a b18 swap and i have a set of dc sports 4-1 headers.. I plan on buying a full TANABE catback system. Is this blot on or I have to have it custom fitted since its a integra motor not the stock with the stock headers. please give me a answer ASAP before I buy the system. If it wont work how do you guys do it with swaps in your egs if you wanted to do a catback. lmk Thanks
Old Jan 9, 2006 | 11:44 PM
x_outlaw_x's Avatar
it will work
Old Jan 10, 2006 | 12:26 AM
just making sure... im getting a 92-95 hatchback TANABE catback system. not a integra catback. Thanks for the help bro, ill be getting the system soon .
Old Jan 10, 2006 | 12:53 AM
CRXified's Avatar
Default Re: (Kangolbrand)
i belive if u get a header for teh b18 motor, it will be longer and will not bolt up to the stock civic cat, it has to be moved back, so u might have to do some modification.
im no exhaust expert tho
Old Jan 10, 2006 | 01:02 AM
ya, i was thinking the same cuz my dc headers look a bit longer than a stock header off the stock motor that came in the hatch oringally. any eg owner out there that knows what to do inorder to make this work? thanks for the help so far.
Old Jan 10, 2006 | 01:04 AM
ya I was thinking the same since the dc headers are a bit longer than the stock header on a stock eg hatch . Does any eg owner out there know some way or mod this to work .. please lmk asap. thanks for the help so far guys.
Old Jan 10, 2006 | 01:39 AM
CRXified's Avatar
try getting a header for a b16? im not sure, but 1 way is to cut and remove a piece of ur exhaust and reweld it
Old Jan 10, 2006 | 05:34 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Eg With swaps.... can you still use a full catback exhaust system without having to ajust the pi
Facts:
1. Buy the Civic exhaust
2. All Integra headers EXCEPT THE GS-R will allow for 100% bolt-up usage as long as you have the correct Integra or Civic cat in place too.
3. Any 2.5'' collector "JDM" type header will need customizing piping somewhere - mine is altered at the cat since I also added a 2.5'' cat too.
I know this from first-hand experience. My 1992 Civic had a Gs-R swap first, so I had to extend my exhaust like 2-3'' to accomodate the shorter GS-R header pipe to make the cat and header bolt up.
My Type R swap did not require any mods whatsoever due to it's longer-than-GS-R header.
If you have a GS-R swap you can always just buy the Type R header and still not have to mod the exhaust.
LS swaps are 100% bolt-up as long as you use a header for an LS with a Civic exhaust.
Old Jan 10, 2006 | 10:38 AM
So just get a ITR header and replace dc I have now and the catback should fit?
Old Jan 10, 2006 | 11:46 AM
dohcVTECeg2's Avatar
pick up an ITR header much more bang for your buck there than a DC header
Old Jan 10, 2006 | 02:51 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">So just get a ITR header and replace dc I have now and the catback should fit?</TD></TR></TABLE>
No.
Keep the LS header and it will still bolt right up.
I said if someone had a GS-R swap they need to buy a header for an ITR engine to make it 100% bolt-up.
SpeedRacer34
Oct 17, 2004 05:55 PM
hondasport2000
Dec 17, 2003 06:15 AM
bgoetz
Nov 20, 2003 08:11 AM
