jumping rpm
Old Jan 9, 2006 | 03:04 PM
B-SerioUs EGg's Avatar
B A N N E D
Default jumping rpm
why would make the rpm need jump up and down weird.
***not the idle, just jumps around drastically***
Old Jan 9, 2006 | 06:16 PM
B A N N E D
Default Re: jumping rpm (Frosty R81)
TTT
Old Jan 9, 2006 | 06:20 PM
speedooo's Avatar
check for bad connections
Old Jan 9, 2006 | 06:21 PM
1995Ex_Sedan's Avatar
Many, Many, Many things.
What kind of car is it? Any Modifications? When does it do this? Whats the difference in the jumping? 200 Rpms? 1k? More information would be helpful.
Old Jan 9, 2006 | 06:22 PM
eXcelonTypeR's Avatar
Default Re: jumping rpm (zildude182)
grounds. expecialy the ground on the thermostat housing, made mine jump around like crazy
Old Jan 9, 2006 | 07:26 PM
drevinder's Avatar
Default Re: jumping rpm (eXcelonTypeR)
tps sensor or map sensor gone bad ?
Old Jan 9, 2006 | 07:39 PM
BoostedEMone's Avatar
Default Re: jumping rpm (drevinder)
vac leak?
Old Jan 9, 2006 | 07:55 PM
94_HATCH's Avatar
Default Re: jumping rpm (BoostedEMone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 &raquo;</TD></TR><TR><TD CLASS="quote">why would make the rpm need jump up and down weird.
***not the idle, just jumps around drastically***</TD></TR></TABLE>
It helps when your clear with your questions.
Old Jan 9, 2006 | 10:09 PM
JDMCivicEF9's Avatar
Default Re: jumping rpm (94_HATCH)
Hint!!! Check your distributor!
Old Jan 10, 2006 | 09:41 AM
B A N N E D
Default Re: jumping rpm (JDMCivicEF9)
1992 Civic SI Hatch
94 rebuilt B18B1
generic header, stock airbox
jumping all over the cluster. when im driving, would kill the car.
Old Jan 10, 2006 | 02:21 PM
how rebuilt is it? is it rebuilt from a reliable person? bring it back to them and have them check it out...
Old Jan 10, 2006 | 03:41 PM
tranzvision's Avatar
i just noticed that with mine too..there are times when i'm idle that the RPMs would start jumping around almost to 3k, definitely let me know when you find out..
Old Jan 10, 2006 | 04:51 PM
B A N N E D
Default Re: jumping rpm (tranzvision)
rebuilt by me.
i think it was a bad ground on the thermostat housing. because after i tighten that one down and a few others, its running better
tstevens3754
Nov 18, 2012 09:39 PM
1nsoman1ac
Jul 29, 2009 05:48 PM
poormans_typer69
Oct 30, 2007 05:10 PM
CA6VTEC
Sep 14, 2004 05:57 PM
Racerage1
Dec 21, 2003 01:26 PM
