How to identify if a B18C engine in Civic
Hello. I need to know where to find a block ID casting/ significant ID marks to ID a B18C engine installed in a Civic. I'm looking at a 93 Civic EX tomorrow that supposedly has a 99 GSR engine in it. The guy said it's a B18C1 (Shouldn't it be a B18C5 if from a 99?) Anyhow, Q's like this (and making sure it's not the stock EX engine) prompts me to ask.
If this car really does have the B18C...I'll be gold. I' was getting ready to order one for my 94 Civic. This would save much $$ and effort....especially shipping to Hawaii!!
Appreciate any input.
Schantin
1994 Civic LX M5
2002 Camaro Z28 M6
Schantin
1994 Civic LX M5
2002 Camaro Z28 M6
No B18C1 is correct for a GSR motor. A B18C5 is a Type R motor.
Whether the motor IS a B18C1 is a whole different story that you're going to have to check out. The embedded "B18C1" or whichever motor it is, is usually located in the front of the block right next to the Tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">the diference is in the head...an itr comes from the factory with a bigger cam and a port and polish...same with the ctr</TD></TR></TABLE>
Doesn't end there.
A B18c5 comes with a better intake manifold (stud pattern for the manifold is different between the 2 motors), the b18c1 has secondary butterflies in their intake manifold. The B18C1 has a smaller combustion chamber then the B16 and B18C5 heads. The b18c5 comes with high compression pistons then the B18c1.
Doesn't end here either.
Doesn't end there.
Type-R motors rev higher, have less friction, and there handbuilt. They are overall just better, and thus cost a lot more.
The B18C5 is the ITR motor, and yeah, better stuff like thinner intake valve stems, better exhaust system, etc.
And also dual valvesprings to allow it to safely rev higher, it can go on
Too much money for a small gain though, I would build a poor mans hype r before I dropped 5k on a C5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesV »</TD></TR><TR><TD CLASS="quote">it is hard to use paint and handwrite with a mouse
You can type with ms paint. i dont know why the guy chose to use the mouse, and using a sohc engine pic would confuse a lot of newbies.
</TD></TR></TABLE>You can type with ms paint. i dont know why the guy chose to use the mouse, and using a sohc engine pic would confuse a lot of newbies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDThEnWuT »</TD></TR><TR><TD CLASS="quote">
You can type with ms paint. i dont know why the guy chose to use the mouse, and using a sohc engine pic would confuse a lot of newbies.</TD></TR></TABLE>
i only had the d15beast picture on my computer and didnt feel like going out to the garage to take a picture of the lsvtec im building...and i didnt even think about searching until i typed this sentence
kenheiii
Aug 28, 2013 12:11 AM
it will say B18C1 where that circle is...and it wont look like that just so you know...it should also say DOHC VTEC on the valve cover
