F23 Piston help
Old Jan 8, 2006 | 09:05 PM
XiOus271's Avatar
Default F23 Piston help
ok, ive searched for the past hour or so on here and google, and really havent had any good results. when i get around to doing my h22 head swap, i want to put in new pistons because i want an all motor setup because i wont be able to afford a turbo for a long time, and with f23a5 pistons right now, my compression ratio would be ****. aside from custom pistons (again i cant afford much), where can i find some pistons for my engine without boring out 1mm to reach 87mm? any help is greatly appreciated.
Old Jan 8, 2006 | 11:37 PM
XiOus271's Avatar
anybody? bueller?
Old Jan 9, 2006 | 01:57 AM
Jxi8s2k's Avatar
Default Re: F23 Piston help (XiOus271)
wait you said that your doing an all motor set-up becuase you can't afford a turbo? i thought that you would gain alot more horsepower for the ammount of money you put into a turbo kit that you would into an all motor set-up. instead of buying the whole kits like fmax, you could piece your own kit together. you can learn about all the neccesary parts here
http://www.cse.uconn.edu/~yele....html
Old Jan 9, 2006 | 03:41 AM
Corruption's Avatar
You'd be better off swapping in an H22a, since a F23A5 is a DX engine for the Accord if I'm not mistaken. For the money that you'll be spending on gaining 60-70HP and it being turboed, you can spend less by going NA which is more safe and reliable and getting the same amount of power.
Old Jan 9, 2006 | 03:56 AM
Jxi8s2k's Avatar
Default Re: (Corruption)
doesn't the f23a5 (dx model) have only 135 hp and no vtec?
Old Jan 9, 2006 | 05:23 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corruption &raquo;</TD></TR><TR><TD CLASS="quote">For the money that you'll be spending on gaining 60-70HP and it being turboed, you can spend less by going NA which is more safe and reliable and getting the same amount of power. </TD></TR></TABLE>
You'll <u>never</u> get the same gains as turbo from going N/A, especially not for the same $$$.
To answer the original poster's question: http://www.raceeng.com stocks 86mm 8.5:1 compression forged F23 pistons. check them out. good people over there.
Old Jan 9, 2006 | 09:35 AM
XiOus271's Avatar
Default Re: (notoriousB)
if i could afford the whole h22, then i might have considered it. im going for the cheapest possible route to make a bit more power, but especially torque, on my DX. Yes, my DX is non-vtec, but the h22 head i bought comes with the vtec solenoid and everything so ill be figuring out how to get all that to work. i may be wrong in my pricing idea of turbo vs. NA, but yeah im at least going to build the motor up a little bit till i can afford to get turbo. oh and everything comes out right, with the right cams and pistons, the hybrid G23 is a decent motor for very little money. the h22/f23 hybrid does come out with a low CR, so it is a very boost friendly setup. im in no hurry to get this done, so i just want to explore all of my options on this project.
Old Jan 9, 2006 | 09:36 AM
XiOus271's Avatar
oh and thanks for the website!
Low Ek
Feb 17, 2019 06:55 AM
HFPerformance
Apr 15, 2013 07:39 AM
Khoa_DC2
Apr 10, 2012 10:29 AM
HondaHead211
Aug 13, 2006 09:55 AM
BlackGSR
Jun 23, 2002 05:23 PM
