accord's dying
hey guys every once in a while my car will die in the parking lot it will idle real ruff and then die and then i start it and it does it again? It only does this about every two weeks I have done all maintance except the fuel filter what could be causing this?
it is a v6 automatic 2002 accord thanks for the help?
Injector leak down or low fuel pressure at start up. First try to always let the CEL go off before cranking,[ this ensures fuel pressure at the injector rail] if that doesn't help have an injector leak down test
