EK foglights problem......need electrical help
I've had my 96-98 EK square yellow fogs for almost 3 years now. every year i go thru a pair of fog bulbs(H3?) which seem normal to me since they stay on almost all the time when its dark (coz they look so cool).
I bought the OEM kit brand new COMPLETE with the switch and harness.
A week ago one of the bulbs went out, so I said its that time when i change the bulbs again (as i do every year or sometimes twice a year).
But then this time with brand new sylvania H3s the fogs did not light up at all when put back together. I checked the wiring and ground but there is no noticeable wear or cuts. I popped the fuse panel and checked every single fuse all were tip top. I got a new foglight switch too but that didnt work as well.
WHAT ELSE COULD BE WRONG???
I dont see a proper fuse for the foglights which could have narrowed down my troubleshooting. Could it be an inline fuse? I doubt it tho...
HELP!!! I miss my cool foglights
you know what would be your best friend, a test light
this will tell you if the ground is for sure good, if good it will tell you if the power is good, if the power comes out bad then you go check the fuse if the fuse is good then you check the power supply, im guessing tho when you installed them you just tapped off of the fuse box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 »</TD></TR><TR><TD CLASS="quote">you know what would be your best friend, a test light
this will tell you if the ground is for sure good, if good it will tell you if the power is good, if the power comes out bad then you go check the fuse if the fuse is good then you check the power supply, im guessing tho when you installed them you just tapped off of the fuse box</TD></TR></TABLE>
the ground is good. anybody have a pic of the harness? so i can locate the inline fuse if there is one? i forget, its been awhile since i put them on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm951EK4 »</TD></TR><TR><TD CLASS="quote">
the ground is good. anybody have a pic of the harness? so i can locate the inline fuse if there is one? i forget, its been awhile since i put them on.</TD></TR></TABLE>
how do you know the ground is good did you use a test light? im telling you get one and it will tell you what the problem is
did you use it to test the power wire? if not do that if you did and there is no power where does your "harness" go to? if its to hard to figure out just make your own by tapping into the sidemarkers and bam your done that sounds like a lot simple solution
yes i did.
i'll just replace it tomorrow. for the meantime i went ahead and tapped it onto my parklights and changed the fuse to a 10amp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 »</TD></TR><TR><TD CLASS="quote">if its to hard to figure out just make your own by tapping into the sidemarkers and bam your done that sounds like a lot simple solution</TD></TR></TABLE>
it works now with a 10amp fuse(taillight and license plate light). but tomorrow i'll locate the inline fuse and replace everything like stock.
thanks for the help guys
N1NjA TuRtLE
14
Aug 5, 2012 05:55 PM
greenturtle
Jul 30, 2004 03:56 PM
